    Results 1 to 9 of 9
      DSE control Arm kit
      hello everybody ,,,
      am building a 69 firebird ,,, i just got my DSE control Arm kit(Coilover) ,,, to use it with stock subframe u need to buy the coilover conversion kit ,,, they use Koni shocks that has a bearing on the lowerside that will match their lowerControl arm ,,,is there any other shocks brand that will fit there control arm ,,, and if i wanna go aftermarket subframe in the future ,,, can i use my control arms ,,,for example can i use them on speedtech subframe? is it gonna fit or should i use there convertion kit ? and what do u guys think about DSE kit ...
      i really need ur help guys
      thanks and regards
      any1 care to help ?
      St George Utah
      yes you will be able to use the DES Arms and shocks on a Speedtech subframe. we do not use Koni shocks so there may be some slight modifying to mount the upper but nothing major.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      PM sent
      Orlando, Fl
      demo,
      Here is the pdf for Koni 2800 Series coilovers. You should be able to find the dimensions you need to compare to Penske, Bilstein, et. al.
      http://www.koni-na.com/pdfcatalogs/F...English_KC.pdf
      Nick DiPrenda
      Thank u every1
      i really appreciate ur help ,,,
      see the problem is i have got my DSE control arms (upper and lower"the lower has bearing for the shock) however i have not buy the shock and the spring yet ,,, now i want to buy the speedtech subframe and i like the QA1 coilover,,, i contacted DSE and asked if i can use the Arms with Qa1 and speedtech frame they did not give a clear answer yet ,,,
      so plz guys should i order the koni shock or QA1 shock will do the job ,,,because i noticed that QA1 shocks has also a bearings in the two ends of the shock ,,, not sure about the size ,,, but again thats y i need ur help ,,,
