      Jun 2008
      massive vacuum leak
      i have a 86 tpi motor that appears to have a massive vacuum leak..
      there are no emissions on the car as it is in my 67 camaro.. i have looked all over the place and can not find any spots that are sucking air..
      are there places on the tpi setup itself that are hidden from sight or obstructed by other components.. the car is running so rich trying to keep up with te amount of air its taking in apparently...???
      Rockford Illinois
      Check your map sensor to see if it makes a difference if the hose is removed. The hose could be ok and it could leak and give a false signal.
      Other than that maybe the vacuum booster? isn't that hose tucked up in there where you can't see it ?
      You did say Big Leak.
      Aug 2005
      Patterson, NY
      If you have a huge leak it would be lean, or idle too high. If it's actually running rich it's adding more fuel than needed for the air coming in. Are you sure you don't have a sensor issue instead?
      It's easy enough to find out if you have a leak: Get a propane torch, and with it on, but not lit, so just the gas comes out, wave the tip near any joint, hose, or other potential leak point, and if the idle increases you've found the leak.
      Jason Scheer
      May 2002
      Northern California
      How about a detailed list of symtoms and someone here can assist you.
      A common area for that engine is the intake manifold base. It will leak but its hard to find. After you do a good checking overall (using Jason method), pull the pcv hose plug it up and hold your finger over the return hose. You should not feel any suction.
      If its running too rich, check your injectors and cold start injector for leakage.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jun 2008
      the idle is very rough and it surges .. once it is warmed up a bit.. it will idle not as rough but it will still surge up 250-500 rpms searching for a idle.. there is not cold start injector on this setup ..
      i will try the propane method and look for the leak .. what exactly will i be looking for the engine to do using this method,, as it is already surging .. with it hold a higher rpm?
      thank you guys in advance for all the help.
      Aug 2005
      Patterson, NY
      Yes, the idle will increase when the engine starts sucking propane.
      Jason Scheer
