      Mountain View, CA
      Transmission dimensions
      My search-fu is weak today.
      Do we have an existing thread where the lengths of various manual transmissions (I'm looking for distance from trans mount to bellhousing mounting surface) are chronicled?
      True T.
      My blog
      Houston, Tx
      Mountain View, CA
      Are all the TKO's in the 15.8" range?
      True T.
      My blog
      The TKO's (500 and 600) are all the same. If you go to the below link it will show you a good diagram of the TKO.
      http://www.classicchevy5speed.com/TKO-Details.aspx
      Scott Lindquist
      www.cms-grp.com
      PH: 760-438-2244 (ext 102)
      Mountain View, CA
      Thanks Scott.
      I'm trying to get all of my fab work on the car completed before it goes to the cage builder. One of my projects is a trans x-member that welds to the insides of the rocker panels, subframe and tub with a bolt in mount for the trans itself. The cage will tie into the x-member.
      I'm trying to ascertain the delta between the lengths of the TKO and common T56's to determine if I'll have enough "wiggle room" for either so I can install the unit now. Or if I'll need to wait until I have the trans in hand to complete this step.
      True T.
      My blog
      Dec 2008
      Knoxville, TN
      Trans Dims
      We have a very comprehensive table of dims for our product, including:
      - TKO
      - T56 - old and new (Magnum)
      - T45-RS
      Where do we post it?
      Mountain View, CA
      Right here and I'll make it a sticky.
      True T.
      My blog
      Manteca, CA
      I'd love to see dimensions other than the length..... such as the height and width at several spots..... this would be great for people that are trying to figure out just how much (if any) tunnels mods they may need etc...
