    Thread: Lt1 or ls1
      Jun 2009
      Lt1 or ls1
      hey guys
      i have a question, i was going to do an engine swap to my regal with either an LT1 or LS1. i need some opinions from you guys which one whould be the best, easiest to install, easiest on budjet to swap in and maintain?? and both can go with the 4l60E right?? Any other info will be appriciated
      OK
      cheapest swap would be the LT1. LT1's are cheaper, cheaper to tune, won't require any special motor mounts. The LT1 is your basic small block, so a lot of parts-headers, radiator ect. can be re-used or found for cheap.
      LS1-better all around motor in my opinion. Cost will be greater to swap. Also LS1's put up better MPG than most LT1's, so if it is your daily driver, it could be cost beneficial in the long run.
      With the LS1 you will need a Radiator, motor mounts, headers, tune, wiring harness, crossmember for 4l60e. There is probably a few other things that I am not thinking of.
      Hope this helps.
      Asheboro NC
      ^^exactly what he said!^^
      oh, and ebay is a good friend for people with a budget
      Jacksonville, FL
      I have a complete bolt in setup (LT1/4l60E) that is perfect for a first gen camaro/3rd gen nova. When I say complete bolt in, the only thing missing is the fuel system (tank and lines). I am getting ready to do a L92 swap. PM me if you want details.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Sep 2002
      San Jose, CA
      Just curious - why are you moving away from the Turbo-6
      Those motors turn into complete animals without a whole lot of tweaking
      Just call me Brett
      Jun 2009
      well lowend i wish i had the turbo one but mines is a clone regal limited V8 not to be confused with grand national or t-type
      Everett, WA
      If I were to do it over again, I'd go with a LSx. Way more aftermarket support, and the heads are much better than the LT1.
      Why did I go with the LT1? I had a good one sitting around. Famous last words!
      The few, the proud, the crazy... the LT1 owners.
      Sep 2002
      San Jose, CA
      There is a lot to be said for the "bolt-upness" of the LT1. It's basically drop in with a new ECM.
      But if I was gonna do an LT1, I'd probably go with a traditional smallblock with a TPI based setup. Buy a ZZ383 and install an Accel DFI setup on it
      Just call me Brett
