      new york city
      Butt connect 2 battery cables
      This a pretty simple question, but I cant find anything to do it with.
      I am extending my battery cable which is 1/0 gauge, how do I connect them butt-to-butt. I cant seem to find a crimp connector that big. Can you solder them together?
      Any help would be appreciated.
      Oct 2008
      Kingsland, GA
      solder is always preferred
      west michigan
      With such a big cable I probably would just use a solid single wire but if you have to connect them I would probably put two connectors that have a hole in them and put a screw in them to hold them together.
      how long is the cable? are you trunk mounting your battery?
      Chad Read
      Jul 2008
      Bethlehem PA
      Quote Originally Posted by CRead01 View Post
      Definitely the best way with cables that big. Heavy crimp-on terminal ends like the ends that bolt to starters or starter relays. Usually require a special crimper with an anvil you pound with a BFH
      Also look for a special terminal connector (usually a bolt inside a plastic cover)
      Most battery shops should be able to help.
      John at SC&C
      Savitske Classic and Custom
      NEW # 610-381-6100
      '87 Buick Regal Turbo T - Since New
      Lots of SC&C, Fays2 Watts Link
      Boze Pro Touring wheels,
      Baer 13" Pro+ & SS4+
      Shaved door handles
      Custom S/S Exhaust
      Aug 2006
      fort myers florida
      Check at a hardware or welding supply store for male and female end's for welding cable's. The cable will go into a sleeve and be locked in place with set screw's and the end's will twist lock into each other. I have used these on drag car's and they work real well.
      Nov 2007
      Pittsburgh,pa
      If you are set on splicing the I would use a split bolt. Sold in any electrical supply house(maybe home depot or lowes). Used all the time for connecting big machinery. Personally I would run a new wire. Jmo.
      Houston, Tx
      the proper cable shouldn't be that expensive... How long do u need it to be?
