    Results 1 to 18 of 18
    Thread: Need Advice...
      Pittsboro, NC
      Need Advice...
      Hey guys,
      I am contemplating whether to sell my 69 camaro to buy a Corvette Z06. If Im having major brain issues here, let me know. I am not sure what the price I should ask for, especially in this economy.
      The paint is about 15 years old as I have had the car almost 10 and the previous owner had it painted 5 years before. There is only 1 bit of rust that I have seen and I have had the floorboard and trunk stripped down to bare metal. The small rust is on driver door down on lower side near front fender and I am fixing it whether I sell it or not.
      The car is an original matching numbers SS. I have the original engine that will go of course with the car. The T350 goes as well, but have not checked those numbers. The car was an originial auto with T350.
      Here are the mods etc I have done to the car. ~2500 miles on motor and trans. I have to look at odometer to get exact number.
      Paint: Hugger Orange (originally Olympic Gold)
      Wheels: Vintage Wheel Works 17x8x4.75” front – 17x9.5x5.5” rear
      Tires: 245/40/17 front – 275/45/17 rear
      Engine: Professionally built 355 cubic inch small block – 475 HP @6400
      Will provide all engine component details to potential buyer
      Transmission: Tremec TKO-600 5-speed
      Rear Differential: GM 12 bolt positive traction w/ 3.73 gear ratio
      Brakes: Baer track system in front (13” cross-drilled/Zinc washed rotors), touring system in rear (12” cross-drilled/Zinc washed rotors) with Hydratech’s hydraulic brake booster
      Shocks:
      • Front: Koni adjustable coil-over designed by DSE
      • Rear: Adjustable conventional style
      Suspension Modifications
      Subframe converted to coil-over front suspension using the (DSE) Detroit Speed & Engineering coil-over conversion kit
      DSE tubular upper control arms
      DSE subframe connectors
      AGR custom valved 12:1 power steering box
      DSE tubular tie-rod sleeves
      1 1/8” sway bar
      DSE steel sleeves with Delrin bushings in lower control arms
      DSE aluminum solid body mounts w/ stainless bolts
      Hotchkis 2” drop multi-leaf springs in rear with additional Ύ” aluminum lowering blocks
      Ididit tilt steering column w/Borgeson joint
      Tom’s Differential Axles
      Interior Modifications
      DSE steel custom dash - Autometer gauges with LED bulbs and ignition moved to dash
      DSE hoop bar with removable cross bar
      Custom made aluminum pedal covers
      Corbeau TRS seats w/ 3” racing harnesses
      Stock backseat re-covered to match front Corbeau seats with Corbeau 2” factory latch style seatbelts in rear
      Dynamat Xtreme insulation installed throughout car to reduce road noise
      & vibrations
      Sparco removable steering wheel (horn still works)
      CV Products aluminum shifter stick and ball
      Anvil Arms Carbon Fiber Satin A-Pillar moldings
      New carpet, doorpanels, window cranks, dashpad, rearview mirror, dome light
      Other Modifications
      DSE Firewall Fill Platel installed.
      Car rewired with Painless Wiring 18 circuit harness and GM weatherpack connectors used for easy disconnects
      Vintage Air Front-Runner serpentine pulley system
      DSE aluminum hood hinges
      DSE Billet Hood Latch Pin and Spring Collar
      DSE aluminum close-out panel
      DSE power steering pump & reservoir
      Be Cool 4-core aluminum radiator w/ Spal electric fan
      DSE selecta-speed wiper
      DSE modern headlight kit
      DSE aluminum trunk battery mount w/ optima battery
      Flowmaster 2 ½” H-pipe exhaust system connected to 1 5/8” Hooker Super Comps w/ceramic coating
      Marquez Design components
      o aluminum marker plates, tail light markers, cubic inch numbers, aluminum door jamb vents, stainless hood adjusters, and stainless door strikers
      Included with Car
      Wilwood 1 1/8” Black Powder Coated Aluminum MC (new in box)
      Prodigy Customs compete stainless bolt kit (new in box)
      Original SS Hood
      Original 69 seats
      1970-81 2nd Gen Camaro bullet mirrors
      DSE powder coated Compac bracket for Vintage Air Gen II system (new in box)
      Turbo 350 transmission
      Thanks guys....I willl post pics asap.
      __________________
      Jay
      Miamisburg, Oh
      Quote Originally Posted by JayBird View Post
      Hey guys,
      I think you're goofy.
      69 RS
      LS7, T56 and other cool stuff
      Back on track in late 2020!
      Build Thread
      Monterey Peninsula
      personally I wouldn't do it but you have to do what makes you happiest...
      www.buickfunnycar.com
      Sep 2008
      miami.fl.us
      all the time and money in your '69 is more than the Z06. Z06 will be out of style eventually.
      EngineeRunner - Vintage Ford - '66FBGT + '68F250CC4x4
      Jan 2009
      La Mesa, CA
      Did you do the work on the camaro yourself?
      I have an odd way of thinking about owners and their cars. If you put all the sweat and blood into building it, I would have a hard time believing you would want to sell it. If you had someone do it for you, I think it's just another "object" to you...and you might as well sell it and buy the vette.
      I could be way off, but I've developed a bond with my car throughout this process and I know I'll never sell it, but that's me.
      Len L.
      1970 Mustang Fastback
      Pittsboro, NC
      Thanks for the replys fellas. Yes I have done all the work myself minus the engine build. Im torn, dont get my wrong here...but thats why I'm asking. If I keep it, I will paint it and install air.
      Im afraid I would regret, but my wife and I could take the Z06 on longer trips. I dont take the 69 as Im afraid of theft. I know the corvette can get stolen but its not as likely.
      Sep 2008
      miami.fl.us
      i plan to put Lo-Jack once i'm done with a new 9" rear, new suspension/wheels/brakes.
      Jun 2009
      Massachusetts
      If its just to go cruising, keep the 69 and get a good stated value insurance policy and drive the damn thing and stop worrying over it. This has been my approach @ 7-10K miles a year and if the worst happens I'll take the insurance $$ and start over as 1/2 the fun is in the build. If you want to go road racing I'd buy a used Z06 in a heartbeat. I've seen low mileage '06s and '07s in the low $40s. Not bad for a $70k car and I think a giant chunk of the depreciation has already happened. Go on the corvetteforum.com or corvetteactioncenter.com as there a ton cars for sale.
      Larry Nirenberg
      '23 Mercedes S500
      '23 Corvette Z06
      ’62 Chevy C10
      Keep the 69. It's an investment - it will only go up in value whereas the ZO6 will only keep going down.
      Get a lo-jack and a good "you really shouldn't have stolen this car" tool
      Los Angeles, CA
      +1 to everybody that's said keep it and get a lo-jack / gps tracker and enjoy it (and maybe see if you can find a used Auto Taser steering wheel lock on Ebay to provide an obvious theft deterrent).
      John B.
      Sep 2002
      San Jose, CA
      I struggled with this myself a few months ago over my '71 Camaro
      My storage space was gone. I was strapped for cash. I barely drove the car, and I realized that while the car was be done to 99% of the world... it would need another $15K to be right for me.
      Just couldn't justify it
      Ended up selling the '71, and my normal driver to buy a Subaru STi for a dual purpose driver/auto-xer
      For now it's the right decision; but I don't doubt that I'll regret it later.
      It's really a question of your needs. Don't worry about what your buddy's will say if it's gone.
      NOW - since you seem to be doing ok on the cash side of things. Have you considered keeping the '69 and buying something a little more daily driver/budget oriented for the trips?
      Just call me Brett
      San Antonio, TX
      Im afraid I would regret, but my wife and I could take the Z06 on longer trips. ....
      I could not take my wife anywhere in a Vette, there is barely space for her shoes for 3 days...lol.
      I'd install air in the fine '69, LoJack, elec fuel pump, and you can shut that mother down with 1 phone call.
      If the wrecker was used, they better be fast, and smart, and if the worst does happen, make sure your insurance covers the full value.
      Southern Indiana
      I agree you will regret getting rid of the Camaro. The Vette your looking at sure wont be as much fun or the head turner the Camaro is, the work you have done is part of the payoff.
      Heck look around and find a cheaper slightly banged up Vette, get a local shop with good rep to repair the body and do a few minor mods and have a weekend driver. Then when the Vette gets hit or stolen you have insurance cash for Camaro.
      I agree Lojack and there is a GPS type of trackin g I think it was Prodigy or someone on here.
      I also agree with the electric pump kill switch.
      Last year of the year before local Harley dealer had his RV,trailer and motorcycle stollen, he got RV and empty trailer back, and they came and wanted to booby trap it so it has a hidden fuel pump cut out. I told'em to also add a good silent alarm with ignition cutout.
      Slow thieves down and they will quit and go away, good insurance will take care of damage/theft with stated value policy.
      And if the Corvette is for long trip just rent one of the darn things, much cheaper in long run and if it has issues the rental company works the logistics out!
      Pittsboro, NC
      Thanks for the feedback guys. I really appreciate it.
      Apr 2004
      OKC, OK
      Why get rid of an investment asset with potential to appreciate and sell it to purchase another asset you know will depreciate?
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Aug 2001
      Connecticut
      In the long term you'll miss the camaro and it is harder and more expensive to replace. Suggestion, keep the camaro, save a bit and pick up a used C5, they can be had well under 20k and are a better car for long trips than the c6z... the z is a blast, but it's a lot of car, and being a track car it rides stiff. Also if you are thinking of something the wife can drive, be wary of the c6z unless she is a real gearhead and driver-- I'd toss the keys to my c5 to anyone and not worry, the car is well mannered, the z06's traction control is set loose and that car comes on like an animal at 3500rpm, it will jump sideways and over the yellow line on dry pavement, 1st and 2nd gear have traction 'issues'... lots of fun, but not for everyone.
      Plus, c6z's are still on the down slide on price, wait for next year and they will be available in the high 30's.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Indiana
      First of all, with all the money you spent with DSE, THEY should chip in on the Z06! [tell Kyle I told you that].
      I have a 68 Camaro and a 2007 Z06. I love both of them amazingly equally. Typically I couldn't care less about a Corvette, and really still don't, but any hotrod with that much aluminum, titanium, magnesium, and carbon fiber is cool, even if it looks like a Corvette!
      The Z06 is VERY comparable with Velocity in several areas. The accelleration is similar, the braking is similar, and the handling is similar [beleive it or not].
      Velocity rides MUCH better and is at least as comfortable to sit in. The Z06 has a much better stereo, A/C, guage package, and much less wind noise.
      The big difference is that the Z06 will do all this with little or no maintainence. What little the Z06 requires can be perfromed at the Chevy dealership. Velocity requires personal [out of warranty]attention from time to time.
      Looking down the road I think the Z06 will hold its value better. It is a known, accepted entity. ANY hotrod will be subjective to the current and next owners tastes.
      The problem is, this is not really about money. If it were we would be talking about an Impala or a Camry and not Covettes and Camaros.
      Here is a thought...rent a Corvette for a weekend to see if it helps make up your mind. Good Luck!
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Pittsboro, NC
      Hey Bret. Thanks for the advice. I've known Kyle and Stacy for a several years now and I've told him before my car should have been an R&D car. I'll make sure I tell him you said that. Does that mean if I some products from you, you'll chip in? LOL
      I plan on keeping the 69 finish the AC and paint it. Then in 2-3 years buy a C6 Z out right.
      Thanks again guys for getting my head straight.
