      Feb 2009
      Lower Alabama
      H.D throttle setup
      Hey guys, I'm looking for a cable throttle setup for my 67 camaro with 2 holleys. I have the Lokar setup but its so flimsy I dont feel good about it. I used the same setup on a car with 2 Demon blower carbs and had to really modify it to get full throttle. Lokar uses a small braided cable jacket that bunches up and gets shorter with the dual carb tension. Does anyone make a better cable setup than this. I want the car to be trouble free as possible and I'm scarred its going to break. This setup probably works good with single carb.
      Thanks Kevin
      Loganville, GA
      I have a lokar pedal and cable on my 67 El Camino with 2 Holleys on a crossram and it works flawlessly. It's not a blower setup so that may account for some differences. You could always try adapting motorcycle cables (clutch or brake), they are a good bit thicker. Don't know how well it would work, though.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Feb 2009
      Lower Alabama
      Thanks Randy, the motorcyle cable might be a good solution for me. The lokar pedal works ok after building a thicker cable bracket that doesn't flex like crazy. I'm gonna go to a motorcycle shop and check that out. Thanks Kevin
