      Jun 2008
      Waukesha Wi
      Power/Ground Dist blocks?
      Hi everyone
      I am looking for a amp distribution block that is good looking and can do both power and ground. It also has to be priced reasonably.
      I am redoing the interior of my daily driver after being tired of water leaking in. I am going to dynomat and replace the carpet and rewire the stereo at the same time.
      I have 3 amps and currently has a small crappy looking dist block for the power and the grounds are just all tied to a bolt.
      I plan on selling this truck later in the year and I want something that I would be pleased with and would look good to a buyer.
      The way its wired currently is horrible as I had a buddy do it while I was working on the engine.
      I have found this
      http://www.sherco-auto.com/Merchant2...tegory_Code=MA
      But that place does not sell it anymore and I can't seem to find anything I like on ebay either. I would settle for a real nice looking power dist block and use my current one for the ground also.
      Just wondering if people have any recommendations on what they have used etc. I have a tsunami wiring kit so I would prefer to use all the same brand but will switch brands for the right deal.
      Thanks for the help!
      David Van Hulst
      '91 GMC Syclone #892
      '92 GMC Sonoma GT #516 Daily
      '92 GMC Typhoon #0076 Dads
      http://community.webshots.com/user/syclone892
      Oct 2008
      Kingsland, GA
      http://order.waytekwire.com/cgi-bin/...EBID(S0020):01
      These guys have just about everything you will ever need.
      Chicago
      Jun 2008
      Waukesha Wi
      Not sure but I don't think waytek deals with the car stereo kind of parts.
      Forgot to mention I will be using 1 4ga in and 4 8 ga outs, as one amp as dual 8 ga terminals.
      I look the way that street wires block looks, have you used it and have experience with it or just saw it on ebay?
      David Van Hulst
      Oct 2002
      Houston,TX
      I would not ger any with fuses, you only need one fuse, the one in the amp. If you want to can add a breaker on the main wire when it comes off the batt, other then that its just more crap to go wrong.
      http://www.hifisoundconnection.com/S...8049/SFV/30046
      James J.
      Dec 2007
      arizona
      i like you have three amps and use the rockford distrbution block one in three out i have one for ground one for power they work and look good and available for about 20 each local sorry i don't have the part number but i probably get a pic later if interested good luck!
      Jun 2008
      Waukesha Wi
      gr868 That sounds like what I have for the power currently. I was hoping to get something nicer etc but since this is a dd and not a show truck plus being on a dave ramsey budget I think I will be just getting another one of those and calling it a day.
      Once I get the syclone driveable and actually have a stereo in it again I will look into this stuff some more and get the nice stuff
      Also not really liking the idea nor do I recommend only running the fuse in the amp. Defiantly run a fuse as close to battery as possible first after that no need for additional fuses. Not having a fuse at the battery is a good way to make a nice vehicle crispy
      JamesJ If you meant differently excuse me just wanted to make sure thats not what you were recommending.
      Thanks for the help Guys
