Thread: Oil Control
I would definitely upgrade the pan. The baffling in a road-race pan should be enough if used with the correct pickup for the pan.
I don't know about a "drop" in pressure when refilling an accumulator, but if the accumulator empties it will take a little while for the pressure to come all the way back up. I think the high volume pump will help a lot with this.
CCV: if the baffles in the valve covers are insufficient to control the oil then I think you are going the require a catch can. The oil that gets sucked/blown out the covers will have to go somewhere.
Jason Scheer
