    Results 1 to 20 of 20
      Indiana
      Cross-flow or down-flow
      Which is better and why?
      The reason I ask is because I'm in the market for a new radiator for the Chevelle. It currently has a Northern aluminum rad w/ twin 10" fans. In normal driving around town, outside temps in the 80's or so, the rad has a hard time keeping the engine temp under 200*F. I know it's not overheating, but I'm sure the current rad is at its limit. Once I start to push it I doubt the rad will be able to keep its cool.
      Anyway, I called Ron Davis to order a new rad (BTW, Tim no longer works there). I told the new salesman (Dennis) that I'd like to go with a cross-flow and he said that would be a custom rad and that I would need to provide all the dimensions for them to build it. Not a big deal, but that means I'll have to take the Chevelle apart to make sure I get the correct measurements. If I go with a down-flow then I won't need to do that.
      I know for a fact the Ron Davis down-flow works good because that's what I have in the Elky w/ a/c and it's never had any cooling issues regardless of outside temps w/ or w/o the a/c running.
      For simplicity sake I'm leaning towards the down-flow. However, since I intend to run the Chevelle harder than the Elky, I thought a cross-flow might be the better way to go.
      So back to the original question... Cross-flow or down-flow, which is better and why?
      Thanks!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Fontana, CA
      Dual pass? They work really well.
      I know, now I'm just adding to the mix.
      Nick R.
      Indiana
      Quote Originally Posted by 6'9"Witha69 View Post
      Is that available in both cross-flow and down-flow?
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Morehead City, NC
      Quote Originally Posted by Yelcamino View Post
      Herb, The radiator in the 66 I'm just finishing is a crossflow from RDR. Seems to be doing fine. It was a special order for me, but it most likely has a p/n now. I can check the invoice to see how they listed it. Has the big Spals(13's)
      Mike
      Sep 2007
      Thehoodstock,GA
      I went to this page to order my dual pass Ron Davis radiator:
      http://www.rondavisradiators.com/offroad.htm
      The dimensions are listed. There was no mention of it being a custom order.
      MarkK
      Indiana
      Quote Originally Posted by Mike Holleman View Post
      Mike
      RDR = Ron Davis Racing?
      A part number would be great! Do you have any pictures of it?
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Indiana
      Quote Originally Posted by BossaNova View Post
      I checked out the link. One of those might be a possibility.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Oct 2008
      Durham,NC
      Call Frank @ Prodigy he has a Sweet Radiator ( search on lateral-g Prodigy Radiator ) or give him a call. I am working on my commission check from him lol
      Indiana
      Quote Originally Posted by brans72 View Post
      Wrong year. The one Frank is selling is for '68 and newer.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Aug 2003
      LOL! Brandon, your awesome.
      Herb,
      Give me a call, we can do a down flow or a double pass. The double pass MAY work depending on the front drive your runnig.
      I am working this weeekend.
      So Cal
      One advantage of the cross-flow radiator is the cap is on the cooler low pressure side of the radiator, unlike the down-flow that has the cap at the top on the hot side.
      This makes the radiator cap's job much easier, and allows you to better utilize a coolant recovery system.
      Take some measurements and install one of the readily available universal-type radiators, they cost around $200. A little imagination and ability to make mounting brackets will get it in your car without too much trouble.
      I put a 24" wide one in my '64 Tempest, but a 26" wide one would have fit with a little hammering down at the bottom of the sides where they taper in a little.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Oct 2008
      Durham,NC
      Frank maybe you need to do a full post up for the fellows here and lateral-g again on your Sweet Setup from Prodigy. Herb, Frank will set you up with the right deal your in good hands. Brandon
      Morehead City, NC
      From the invoice, item number 1c-cu2819, description, custom 1A-28193DT-2. No pictures uninstalled. After the fire it is black Imron. It is a typical nice RDR piece.
      Mike
      Indiana
      Frank, stand by, I may be giving your a ring.
      Mike, thanks for the info off of your invoice. I sent an email to RDR with the numbers asking for a price and specs. If I don't get the right answer, I'll call Frank to see what he can come up with.
      Thanks guys!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Greenwood, SC
      Looking last night at Radiators and I had the same questions.... but I thought of a few more. I don't want to hijack, but its better than starting another thread i guess. Anyhow:
      Crossflow vs. Downflow: Answered
      Dual Row vs. Single Row: Dual has more surface area for cooling?
      Tube Size: Bigger is better? More flow?
      Core Thickness: More surface area for better cooling?
      Lastly, do different engines require different setups? (Not including 350 sbc to LS1 because of reverse flow) What about Ford 352 FE to a 460 (385-series) engine? Would a different radiator be required?
      Thanks in advance and sorry to hijack
      JC Scott
      Jul 2007
      Los Angeles, CA
      Really like my Ron Davis double pass, great quality piece:
      Oct 2008
      Durham,NC
      So Herb which radiator are you going with?
      Indiana
      I'm still in decision mode. I talked with Bill at RDR and he's supposed to email a diagram with the important dimensions on it for the rad that Mike has in the '66 mentioned above. If he doesn't come through fairly soon, I'll be moving on to Frank and/or PRC. Speaking of PRC, the other day I ordered one of their totally trick oil coolers w/ the dual 5" fans.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Oct 2008
      Durham,NC
      If you like trick items give Frank a call not to mention he will save you a few $ I bet!
      Indiana
      Too late. I just got off the phone w/ RDR and I ordered the same setup Mike has in his '66. It's a double-pass cross-flow w/ two 13" fans and integrated shroud. $800 plus shipping. I think that's a pretty good deal.
      Frank didn't really lose out as I'll be ordering another set of Forgelines from him down the road.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
