Results 1 to 1 of 1
06-30-2009 #1
- May 2009
- Houston
- 149
Dodge Ra1500 front spindle - Measurements needed
Well if I you have a hub or spindle laying around can I bother you to take a few measurements?
If you have the hub laying around could you measure: A B & C. I also need the outer diameter of the hub - the part that fits into the spindle.
If you have the spindle laying around could you measure: A B C D E & F along with the inner bore for the bearing.
Here is an image I whipped up in autocad, the rendering is proportionate for easy viewing. Aalso labeled the measurements so its not confusing
All else fails I will pester some poor parts counter man..
only thing is I have no digital caliper :(
clint
