    Results 1 to 12 of 12
      Texas
      PS Control Valve
      The Billet Specialties Control Valve - they say its for GM PS pumps - does that mean it will fit a Type II, LS1 pump or both? Looking to put it on my LS1. Thanks. -Bob
      http://summitracing.com/parts/BSP-RP1300/
      -Bob (66 Nova)
      Mountain Springs, Texas
      My assumption is that it installs in the rack. The AN fitting end is where you connect the line from the pump so it should work with either pump. I ordered one of these yesterday and hope to install it this weekend.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Auburn, WA
      I posted this in the other forum as well:
      What steering rack do you have?
      A better option is a pump from KRC. We stock these pumps after becoming a believer when we installed them in our own vehicles - hands down the best pump available. You can tune the flow rate from 1.5GPM to 3.2GPM - a significant change in steering effort.
      Some Ford racks require 1100PSI, while most GM pumps are way more than that. If your pressure is too high (which can damage the rack), we have a pressure reducing kit. AGR racks, for example, require 1100PSI and 3GPM for proper feel.
      Also, that will fit a LS pump - but pressure will remain unchanged.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Hi Matt. This part is similar to one sold by DSE for the same application. My assumption was that the restriction will result in a pressure drop due to the fluid flow. It would also reduce the flow. Is that not the case?
      What does your pressure reducing kit contain? What is involved in the installation? Since I have an AME subframe and an LS1 pump I am interested to hear about this before I go to the trouble of installing the Billet Specialties flow control valve.
      Could you post up some pictures of your pump installation. It would be interesting to see.
      Don
      Texas
      Perhaps it will work in your rack but mine is inverted flare fittings not o-ring. Now the LS1 pump is an o-ring type fitting and I assumed it had to go there. Guess you'll find out when you get yours.
      edit:
      Now I see on BS's site their PS conversion fittings for and including up to 88 TBird racks (mine is an 86) and they are o-ring, not inverted flare, but they don't give any sizes or type (english or metric) - I checked again and my rack fittings are o-ring not inverted flare like I thought. (http://www.billetspecialties.com/ite...d=221&pid=1020).
      -Bob (66 Nova)
      Quote Originally Posted by BBPanel View Post
      Matt says it goes on the LS1 pump and he knows better than me. I'll let you know.
      Texas
      How about the pressure vs flow issue you brought up?
      -Bob (66 Nova)
      Auburn, WA
      Yes, those go on the pump itself. The rack has no removable fitting, it's a part of the casting.
      Anyway, those will not reduce pressure because that is controlled by the blow-off valve located behind the flow control valve.
      Don, your rack (and most Ford-based racks) require 1000-1100PSI. I've run mine higher than that with sucess, but I suggest lowering that long-term. Our pressure reducing kit simply shims the blow-off spring just like GM/Delphi does to adjust pressure. It's pretty simple. Also, you may find 2GPM a bit firm for your application, but it's really a trial-and-error thing. Ours will be 3GPM, but again, trial-and-error will tell you what is best for your liking.
      Which again, brings back the KRC pump especially if you have a LS1 engine. It bolts right in. The flow is far more linear than any factory-based pump out there, and the flow rate is tunable. Ever feel the smooth steering of a M3? That's the only way I can explain it. Just plain awesome.
      Matt Jones
      Mechanical Engineer
      Auburn, WA
      To give you an idea on how these components install into the pump, here's a sketch:
      The flow control valve simply screws into the pump casting. The widget located behind the flow valve is the pressure blow-off valve.
      Matt Jones
      Mechanical Engineer
      Texas
      Thanks Matt for the info. So the KRC is a direct bolt-in replacement? Same mounting, uses fbody reservoir, fbody pulley, etc? When you say tunable - to pressure or flow or both? Can you give us a ballpark cost?
      -Bob (66 Nova)
      Texas
      Question on the shimming - seems like a shim behind the spring would increase the pressure at which the blowoff activates since you are compressing the spring requiring more pressure to move the the blowoff to a position that relieves or bypasses fluid doesn't it? Unless I'm thinking this backwards (which is a real possibility) it would seem like a lower rated spring is what we need - or cut a coil off the spring? Trying to understand how this works. -Bob
      -Bob (66 Nova)
      Auburn, WA
      Bob, the KRC pump will require an external resevoir on LS1 engines due to the clocking. KRC does have an available bolt-on tank, but would be mounted sideways on LS1 engines. LS2s are OK. It's nice to get rid of the leaky plastic tank, it does a poor job of keeping the fluid cool. It also includes a pulley to match the LS1's offset. See here:
      http://www.krcpower.com/catalog_i6511532.html
      Both pressure and flow can be changed, but really only flow needs to be tuned to your liking. Pressure has no effect on steering feel, unless if it's extremely low (say, 500psi for a system that requires 1200psi). Flow can be changed by replacing the output fitting, and are $15 each. The whole pump/pulley assembly is about $270. Quite a bargin for such a well made pump. You will notice a difference immediately.
      The shim does not go behind the spring, actually. The shim goes between the inlet nut and valve body, which then decreases spring preload. Cutting the spring would render extremely low pressure - the shims we supply are only a few thou thick. Also, a simply holding tool is included so the valve body can be held in a vice without damage. Without this, the valve would be nicked and need to be replaced.
      Matt Jones
      Mechanical Engineer
