Results 1 to 18 of 18
Thread: Fuel regulator opinions
06-27-2009 #1
- Mar 2005
- 467
Looking for opinions on the best fuel regulator.
I have a parallel set-up with a Bosch 330 pump into an LS7.
Currently I'm using a Weldon regulator.
06-27-2009 #2Are you having issues, or do you just want to know what the best option is?
Jason Scheer
06-27-2009 #3
- Mar 2005
- 467
At 3/4 throttle I'll see a drop from 58psi to 52-53 briefly.
A 4-5 drop at WOT can sometimes be expected but I would prefer a 0psi drop like when I ran a A1000.
06-29-2009 #4I wonder if it's the pump. Maybe it's the vacuum signal to the regulator that's causing it? Or, if you don't have vacuum hooked up, could the vent fitting be partially plugged?
Jason Scheer
06-29-2009 #5
- Mar 2005
- 467
It isn't a vacuum regulator.
06-29-2009 #6What regulator is it? I took a loon on their site, and it looked to me like all the regulators have reference ports.
Jason Scheer
06-30-2009 #7
- Mar 2005
- 467
Well initially I ran a Weldon without vacuum, now I have a Aeromotive with vacuum. Iam trying to determine which would be best.
06-30-2009 #8I mention the vacuum fitting because if it's got it and that is plugged it will cause problems. They have a special filtered fitting for when you DON'T use the reference, so it won't hold back on the diaphragm.
Jason Scheer
06-30-2009 #9
- Mar 2005
- 467
I am trying to decide if I should tune with or without a vacuum
06-30-2009 #10Why not use the vacuum? It helps keep the injectors flowing properly.
If you don't use the reference port you will have to tune around it being a little leaner at WOT and rich at idle.Jason Scheer
06-30-2009 #11
- Mar 2005
- 467
Thanks, that advice makes sense and that was what I was looking for.
I'll talk with my tuner tomorrow and see what he prefers.
07-02-2009 #12
- Dec 2006
- 25
In your situation, the pressure drop has nothing to do with the regulator. Also, have looked at Weldon's new 1100-A -- its a pretty stout pump and is extremely quiet.
Did you contact Weldon and see what they might think?
07-02-2009 #13
