    Results 1 to 10 of 10
      quick connect fitting on both ends?
      This is driving me completely insane. Does anyone know where I can get this fitting? i cannot find this ANYWHERE. or, if anyone has the tool to make this, please let me know what the cost would be. This is the ONLY piece that's missing from completing my fuel system:
      It's a 3/8" hard fuel line that has male quick connects on either end. Thanks again guys.
      Aug 2005
      Patterson, NY
      You may want to stop in a repair shop and see if they can make one for you. I'm pretty sure the right flaring tool can make those flares.
      Jason Scheer
      Think those are upsets formed by an endforming tool. May want to contact someone like classic or inline tube, to see what they have. Length (minimum length) is critical on these, since the clamp around the unformed tube section
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Den Helder, the Netherlands
      Country Flag: Netherlands
      I know a similar one, however it's quite a bit longer, approx. 12" total length, but that's something you can solve by cutting it up and reconnect using a compression fitting (when you need it shorter).
      Search for Dorman 800155 on e.g. www.rockauto.com , cost: $8.55
      Thanks for all the responses, guys. This fitting will work for me also: Russell PN 640940, but summit and jegs are out of stock and say it will take weeks before i can get one.
      Found a solution
      Found a piece that will work, as I ultimately wanted to go to a -6 AN:
      It's by Street and Performance. I just called them up and described the piece to Mark. He knew exactly what I was talking about.
      (i'm posting this in case anyone needs this info)
      Thanks again for all your input guys.
      Southern Indiana
      If I had see it iI can make them now that I have my hydralic flaring tool.
      Quote Originally Posted by demonpixel View Post
      Comparable to Dorman 800154 (US $8.33 @ rockauto.com) with a compression fitting on one end and going over to -6 AN.
      Mid Mich
      Snap On Hydraulic Flaring tool will make these. If anyone needs something like this PM me.
      Southern Indiana
      uhmmm
      Quote Originally Posted by Pro X View Post
      Or me, got same tool. Great minds think alike in tool purchases.
