Thread: Compressor fills up slowly
06-25-2009 #1
Anyone know what may cause an air compressor to fill up slowly? I found a good deal on one and it has this problem and was wondering if it may be a good idea to buy it and have it repaired or if its even repairable.
Rod B.
06-27-2009 #2
- May 2009
- 99
Assuming that it's not a simple leak on the pressure side at any fittings, hose, pressure switch or regulator (any external pressure leak). I would guess that it's probably the reed valves which control airflow into and out of the head.
I have a compressor that fills up slowly, but that's just the way it is, because it's a 2 HP (running, 5HP "max") motor with a 5.7 CFM (@ 90 psi, 7.1 CFM @ 40 psi) 2 cylinder pump filling up a 40 gallon tank. That's gonna take a while even in top form.
Any and all details would be extremely helpful:
How many pump cylinders?
Rated CFM (@ 40psi or @ 90 psi?)
Tank size?
HP of electric motor (and whether that is running or "max" HP, if unknown which it is, is it 115 volt or 230 volt?)
Different people have different ideas of what slow is, maybe it's just a smallish pump/motor on a large tank. Or maybe it's operating just fine and this person thinks it slow.
How long does it take to charge from empty(and what is the max psi)?
Is it belt drive from the motor to pump?
Is the pump oil lubricated or oil-less (teflon sleeved cylinder)?Last edited by nullshine; 06-27-2009 at 11:34 AM. Reason: Typo
06-28-2009 #3
- Mar 2005
- Jackson Ms
- 1,220
i bought one like that. it had a loose belt!!
saved me $900Chris V
SOLD
06-28-2009 #4
- May 2009
- 99
06-30-2009 #5
