    Results 1 to 20 of 25
      Jun 2008
      Oklahoma
      My Budget Camaro
      Well thanks to all on this site for some renewed interest in a car that i have owned since 87'. My Dad bought this car at a mechanics auction for meno front end just a bare subframe, and a gaugeless interior. I do not have any pics of it when it came home but it was pretty nice, since it had been in the garage since 79'. I spent many nights and weekends getting the body straight enough to paint black. blasted and painted all the suspension parts red this was in the early 90s. This picture was taken in the fall of last year when the disassembly started.
      Jun 2008
      Oklahoma
      I had previously minitubed the car probably around 98' but didn't build a proper shock crossmember. So mocking up for a shock crossmember, cutting the trunk floor and welding in a 4''X4'' C-shaped piece and relocating the shocks inboard was in the plans. I also bought a new tank and fabbed up a 1/2" pickup. The old tank had enough funk to kill 3 or 4 fuel systems. I spent hours reading on this site and bought some parts that may not be the best for a hard core on the track car, but mine will see little track time and lots of just driving. I built a 355 with the small chamber 461 heads, flat top pistons and a hyd. flat tappet cam holley 750vac sec and performer intake coupled that with a TH400 and the 8.5" diff. that I built with 3.73 gears and posi carrier. Thanks to the search function I didn't even have to post a question.
      Jun 2008
      Oklahoma
      I read through alot of info on front end set up and mods that worked vs. the amount of money spent. I ended up with stock arms fitted with del-alum bushings then cut the control arm mounting points off and moved the as per Pozzis' site. I welded the sub 100% lightly blasted then on to paint. The firewall got smoothed and clearenced for the comp 9000 cap. I teach auto refinishing at Tulsa Tech in Ok. so I see lots of colors, It was tough to decide on paint scheme I like two tone and a little color to set it off.
      The car looks great nice work . The firewall looks good all cleaned up. I like the color combanation
      Jonesboro, Arkansas
      I like it too! Is this going to be a single leaf or multileaf rear spring?
      Carl Wilson
      Sep 2007
      Thehoodstock,GA
      Beautiful color combo!
      MarkK
      iceland
      Country Flag: Iceland
      Jun 2008
      Oklahoma
      The car originally was a mono leaf, but I switched to Hotchkis rear springs with the koni shocks from DSE. I bought a rear disc setup off of Ebay they are the LT1 set up and had to be ground to clear my Weld Rod Lites while building the rear housing I narrowed it since it came out of a second gen, while the housing ends were loose I reclocked them so the brake lines and e-brake cables clear better. Thanks for the complements on the colors, I have seen many spectacular looking cars on this site and just kind of borrowed some ideas. I really like the dash that DSE builds, but the cost was a problem, so I built my own and now can understand the cost I think I have about two weeks labor in that thing. But it really looks great in the car.
      Jun 2008
      Oklahoma
      Okay I finished the wiring upgrades, battery & solenoid relocated in trunk. Also installed new junctions and relays for thunderbird electric fan and headlamps. pretty much wired it like M.A.D. has on their site. Motor is in and runs but I still need a driveshaft cut and larger u-joint for the 8.5". I am in the process of color sanding the front clip so I can piece it together. I also am welding in subframe conectors like CarlC has on his site. I would like to see the build Carl did on his cheap aircleaner base that sealed to the cowl hood. When he updated his site with the lsx install he removed that DIY section.
      League City, TX
      Good looking work so far!
      John Brown
      1971 Nova - Project Car
      1990 Silverado - Ridetech StreetGRIP
      Instagram @wilwaxu
      Facebook @wilwaxu
      Jun 2008
      Oklahoma
      More progress, I have the sheetmetal hung on the front and just finished welding in sub connectors. I am just going to roll/brush on epoxy for now, then spot in the paint on the underside and put the sound deadner on the inside. I may be driving this thing next week although I had hoped to be able to attend an event at Tulsa Race Park tomorrow and make a couple of passes. But thats the way it goes.
      Looking good
      Buffalo N.Y.
      Nice job shooter,I would be very interested in pics/details on the wiper motor relocation....I like the color combo too.
      Jeoff J.
      Buffalo, NY
      69 Camaro convertible ~ 350ci. ~ T56
      To all u guys with the knowledge.
      My Ride: http://community.webshots.com/user/yukongt
      Nice guages and color combo.
      Frank
      Jun 2008
      Oklahoma
      Thanks guys the wiper relocation is pretty straight forward. I simply cut the old mounting area out then located it inside the fender. It took several attempts to get the extended rod bent so that it moves free without rubbing. I have pics of the firewall so you can see approx. location I could not find pics of the rod to make it connect to the transmision. I cut the factory arm close to the motor then used some 1/4" round bar to make the correct length and heated bent assemble power up and see where it hits and do the heat bent till you get it right. this is not that hard to do and frees up some room right there by the dist.
      Jul 2007
      Arkansas
      Hey looks like its going to be a great car!!!
      What part of Oklahoma?
      Jun 2008
      Oklahoma
      I am located around Bartlesville which is about 45 miles north of Tulsa Ok.
      Jun 2008
      Oklahoma
      Well the car is oout of my garage and ready for a front end alignment and some miles to break stuff in. I had it running on stands in my shop and the fuel pump went bad. Which was good timing for something like that to happen. Now for some customer cars to build up the play fund again.
      Beaufort , NC
      Looks SHARP!!
      1992 Lexus SC400 daily SOLD
      1966 Porsche 912 Outlaw SOLD
      1968 Ford F-100 sb SOLD
      Sep 2007
      Thehoodstock,GA
      Dang man, that HAWT!
      Enjoy!
      MarkK
