    Results 1 to 20 of 25
      Miami
      Cigarette Smoke - How Do I get Rid Of It?
      any suggestions on how to completely eliminate the smell out of a car interior besides changing the interior?
      I have shampooed the seats, carpet and headliner. Tried white vinger in a bowl. That has toned it down but I want to get it gone!
      Any other suggestions?
      CHICAGO SUBURBS
      The smell stays in all cloth padding etc. Fabreeze or the like works o.k., if you soak it in and let it dry. I had to replace almost everything to be rid of it. Also i took the dash apart and cleaned the heat and defrost ducts.
      Frank B. 1968 Camaro 355 Procharged 6 speed. 1983 V8 S10. 1984 Monte Carlo Magnusen Charged iron 6.0. Plus a few other junkers!
      Jul 2007
      Olathe, KS
      Quote Originally Posted by HILROD View Post
      ...i took the dash apart and cleaned the heat and defrost ducts.
      That is a big source of the odor that most people tend to ignore. I've done the same. It's a lot of work, but worth it in the end.
      Oct 2005
      Orlando, Fl
      You need something that generates ozone. Put it in the car and leave it for a while, just don't breathe the stuff. You might be able to find a local place to rent one.
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
      Nov 2004
      Quote Originally Posted by stealth71 View Post
      this will work if you have a seal on the inside of the car. meaning all the windows, vents, etc... have to be closed. the idea is that all the air is pulled into the ozoning machine including the smell of smoke. personally I dont like it. we have one of those machines here at my work.the machine has to be run for 24 hours min. I own a high end drycleaners we deal with fire damaged clothes all the time. the only truely way to get the smoke out if its really bad is washing. a good soap and really hot water. I know you cant do that.
      I smelled a stale smell in my Benz. it was still under warrenty. they put in a deoderizer in the vents. my bubby was the service writter. he said it was a form of lysol.
      be carful tho. no matter what you use. basically it is bacteria that you want to kill. bleach will kill it but it will damage your fabric also.
      if you do use bleach use a 50/50 mix with water.
      lemme know.
      Will
      Miami
      Yeah the car in question is a 05' Chrysler 300. So the "seal" is there.
      Dec 2007
      Quote Originally Posted by jy211 View Post
      Some of those cars have a cabin filter that is replaceable, might want to check for that if you have not.
      Little Rock, Arkansas
      As said, ozone generator is what the dealers and rental car places use.
      Washington Coast
      It's so hard to get rid of.....My Mother in Law was a smoker and we ended up with her house. It's been three years and every so often I open a closet or drawer and get a wiff of cigarettes.
      It seems like it never goes away.
      DT
      56 Oldsmobile Rocket 88
      ls1 Power & 4L65-E
      Mustang ll Clip & Ford 9" Butt.
      Willwood 13" Discs
      Paint, House of Colors
      Candy, Emerald Green
      PPG off White
      http://dogtagsvette.5u.com
      Miami
      yeah that was the first thing I looked for. Doesn't have it...was hoping...
      Everett, WA
      Autoglym makes a really good smell eliminator in a bottle.
      I tried the Meguiar's stuff - sucked hardcore.
      The few, the proud, the crazy... the LT1 owners.
      Miami
      Quote Originally Posted by 69LT1Nova View Post
      Is that the UK stuff? http://www.autoglym.com/enGB/default.asp
      Everett, WA
      Yep, that's the stuff. Works awesome, and only $8! I got it from TCP Global. Here's a link: http://www.tcpglobal.com/detailsupplydepot/dsd27.aspx
      Autoglym Autofresh is the product.
      When I drug my Nova out from a barn in Oregon, a couple of mice had gotten in there and made it their home STINK! After cleaning out the mouse nest and a couple of mouse skeletons the smell still lingered from the urine and feces. After trying out 3 other products, the Autoglym was the only one that killed the smell.
      Miami
      Thanks! May as well give it a try! LOL
      Central Illinois
      What about Arm & Hammer baking soda? I would take a box and sprinkle it over everything and let the car sit closed up for a couple days.
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      Sunny Florida on the Suncoast
      Here is a used car lot trick to get rid of smoker. A dryer sheet under the seats.
      I would personally use a firehose on the person who made it smell like that......
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
      Holmes Hollow, Ontario Canada
      I've tried febreeze and it works if you keep at it for a while. Charcoal is also supposed to work.
      ____________________________________________
      Scott
      Harriman, Tennessee
      GM sells an Oder Neutralizer product that seems to work pretty well. Part number is: 12346122
      Shiny Side Up!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Washington, MO
      How long did you let the vinegar sit? If you get a big enough bowl and leave it in there long enough it should soak up most of the odor.
      Miami
      last weekend I left the vinegar in a 6" round cereal bowl over 3 days. Car def smells like vinegar LOL. This weekend I left febreeze in the same size bowl. Been like that since Friday, will have to check today. I also injected the a/c ducting with Febreeze.
