      Oakland CA
      Disc Brake parts!
      Well guys its been WAY to long since ive visited the site! The camaro got put on the side when i started taking motorcycles serious... Anywayz i remeber i had a website i used as reference for first gen camaro conversion parts. I had collected quite a few parts. I have c5 calipers, 13inch c4 rotors, touring classics brackets. Now i forget which website listed all the little random bits and pieces i need for the conversion. Everything down to which nuts and bolts were needed... I check david pozzi site but didnt find everything i need. I think it was speedtechs site but it has drastically changed since the last time i visited it.
      Also there was a site i was using for the rear brake conversion from a 4th gen camaro. Since i have a 68 i remeber i needed to have two right(?) side calipers to clear the staggered shocks.
      Anyone got a link to either projects?
      Thanks again,
      Dave
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Apr 2008
      Check out the brake section at www.camaros.net
      Holmes Hollow, Ontario Canada
      ____________________________________________
      Scott
