Results 1 to 9 of 9
Thread: need help with rim size...
06-08-2009 #1
- Mar 2009
- Norcal
- 66
I am getting ready to order the AR CL205 for my 69 camaro. I have hotchkis springs in the rear with C4 rotors and LT1 calipers. In the front ive got hotchkis springs with C4 rotors and C5 calipers. I want to use an 18 x 8 fr and 18 x 9/9.5 in the rear. I am trying to find out what the best backspacing is for both. the rears i want to use a 275 tire so whichever rim width would be better 9 or 9.5? thanks for all the help...
06-08-2009 #2This should help: https://www.pro-touring.com/forum/sh...ad.php?t=46790
____________________________________________
Scott
06-08-2009 #3
- Mar 2009
- Norcal
- 66
theres a lot of talk about wheels spacers in there and the first line says it does not apply to 69. thanks for the link though. i really want to stay away from spacers/adapters due to a bad experience in the past. I just want to bolt on the wheels and drive the car. I know things arent always perfect but the less making car fit the wheel, the better.
06-08-2009 #4
- Mar 2009
- Norcal
- 66
does anyone have a solid number on the backspacing for and 8 up front and a 9 or 9.5 in the rear with an american racing wheel?
06-08-2009 #5
- Mar 2009
- Norcal
- 66
anybody...
06-09-2009 #6Sorry, I thought you wrote 68. PM Jon at driverzinc but I'm guessing he's going to tell you what Musclecarjohn did in this thread: https://www.pro-touring.com/forum/sh...ro+backspacing for the fronts. If my response has done nothing else its bumped your question to the top.
Scott
06-09-2009 #7Call Jon at Driverz
06-09-2009 #8I'm sure Jon will concur since he set mine up...4.75"-4.875" in front on an 8" wide wheel and 5.5" on a 9.5" wide rear...is about perfect on a '69 Camaro.
Problem is,AR doesn't do 1/4" incremental b/spacing so if you run their wheels,you'll either have to use a 4.5" front (which gets you close to the outer fenders) or go to 5" if they offer it...which may limit your turn-in.
AR is currently out of hoops (have been for months) so if you're set on them,be prepared for possibly a lengthy wait.'67 Buick Skylark GS400 funny car "Ingenue" 8/10 HRM / Gasoline (Swedish) cover & feature 2/12
www.buickfunnycar.com
06-09-2009 #9
- Oct 2006
- Corona, CA
- 1,948
