      Morehead City, NC
      rollbar seals/grommets
      We are in the process of installing a rollbar in my El Camino. I'm using Percy's race glass for a back glass and need some sort of seal for the rollbar at the glass. So far what I've had in mind to use has not really looked like I want. Looking something clean and neat that will seal out water.
      Any suggestions? They make real neat ones for Cobras but they are for 2" bars, I have 1 3/4"
      Mike
      Florida
      I went through the same thing recently trying to dress up the holes through my rear seat. Try a local plumbing supply house and look through the racks. There's all kinds of stuff with rubber seals you might be able to try. I found one in some kind of drain plumbing connection and another inside a roof vent pipe assembly. I ended up doing something else in upholstery but you might find something that will suit your needs. You could also try Mcmaster-carr.
      Morehead City, NC
      Quote Originally Posted by NOT A TA View Post
      Thanks for the suggestions John. We have looked at some grommets for pipe that were a bit bulky. I'll try McM/carr.
      Mike
      Big Stone Gap, Virginia
      Make them!
      We made them long before you could buy them in the cup cars! Cut you a ring of aluminum and use a tire inner tube for the rubber. Seals-It make all kinds of different ones also.
      Mark
      Ability is not being able to do something once or twice.Ability is being able to perform upon demand!!
      Morehead City, NC
      Quote Originally Posted by Tig Man View Post
      Mark
      I have thought about doing just that. I found some today at Rhodes Customs in De. They are a pretty fancy piece with a SS ring and a tapered seal. When I get them I may wish I had made em. Most likely they will be very simple. Thanks for the suggestion Mark. You did some very nice work on my buddy Herb's Chevelle.
      Mike Holleman
