      Dec 2008
      Lehigh Valley Pa
      Mounting a transmission cooler
      I am trying to figure out the best way to locate some things. I have a new radiator and have an PermaCool oil cooler with fan. Now fitting the cooler in front of the radiator looks to be a mess as the way things are in there. So I was wondering can I mount the cooler on the backside(engine side) or would this make the cooler ineffective? Also can I mount it so the lines come in from the bottom rather than the side?
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      Aug 2005
      Patterson, NY
      You can mount the lines any way you like, the fluid is under pressure, so it will force any air out.
      Placing it behind the radiator is not the best way, but it will work. However, you need to check the fan to see what way it blows, and if it's reversible. You don't want a fan that blows air through the cooler mounted against the radiator with the fan on the engine side.
      Jason Scheer
