      Jul 2002
      Mesquite, TX
      BBC: Is this a crossover thing, or do I have problems?
      Cleaning up the 396 that's going in the 65 with Engine Brite and a hose.
      To ensure that no water gets in the cylinders, I've removed the rocker arms so all the valves should be closed. It's funny to see the pools of water forming in the exhaust ports - except that #5 and #4 aren't pooling up.
      When I turned the motor on its side to get a better feel for what's going on, I found that water that goes in the #5 exhaust port pours out of the #4 exhaust port, and looking through the intake does not show me water rushing by.
      Is this normal behavior - that #5 and #4 exhaust ports are connected via a crossover under the manifold, or do I have some sort of serious problem here? I wasn't planning on pulling the heads unless I have to.
      Exhaist heat crossover?
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Jul 2002
      Mesquite, TX
      Yeah, that's what I'm wondering. Seems likely, but I've only built the one BBC.
      So Cal
      Definitely the exhaust crossover used to heat the intake.
      Some V8 engines use one exhaust port per head to get heat under the manifold, others (Pontiacs other than Super Duty versions for example) use two ports per head.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Jul 2002
      Mesquite, TX
      Awesome, thanks.
