      Fullerton, CA.
      What to do with 5.3
      I was looking for a 6.0L, a friend found what he thought was a 6.0 ,but turned out it was a 2004 5.3. It was free and complete from intake to pan so I nabbed it without hesitation. It turns out the heads were cracked around one of the bolt holes (apparently common in 4.8/5.3's), but the rest looks in good condition and the truck the motor came out of only had around 60K. SO, should I hold out for the 6.0L and use the 5.3L to mock up and/or get more familiar with the gen-3. Or get a set a heads for the 5.3L and run with it. I'm not looking to make insane power and this will be a somewhat budget conversion. I was shooting for the 450hp range with decent drivability and it will be going into an Chevelle in front of a TH200-4R. Any input would be great. The Gen1 350/320HP that it will replace is showing it's age.
      Mike Martin
      Heavy Chevy 2.0: 71 Heavy Chevy, Unisteer,SC&C, GW,Eibach,Bilstein,Helwig,Showwheels-Streeters, Carb'd LS-327 W-200-4R
      LS-327 powered, Atomic EFI on the way
      Oct 2007
      Wa
      You can get pretty close to your power goal with the 5.3, BRP put down like 330rwhp with little stuff (LS6 intake, z06 cam and long tubes).
      Bob
      Houston, Tx
      st. paul mn.
      there are a ton of things you can do easily to push that kind of power, but somtimes there are better options. oil pan will need to be swapped, cam,the whole front drive system will need to be swapped if you change the intake to a ls6. you can use the truck intake but it's really ugly but it does flow well.might not fit under hood though.if you swap the heads to say a 243 or a 241 your compression will drop slightly because of the chamber size.long tube headers and a ported thottlebody,descreened mass airflow. somtimes mostly dependendt on the front drive fitment in the swap will ad enough extra expence that it would be better to go with a ls1 complete. hope this helps. sit down with a few beers and weigh out the options.
      Fullerton, CA.
      I have the CTS-V pan already and will be running Edelbrock headers and adapter plates. I plan on using Either 243 or 799 castings and mill them to bring back the compression and run either the LS1 or LS6 intake as for the drive system I thought I'd use Kwik Perf brackets with a camaro set up. As for the cam I was looking at a few different cams like a TR220 series from Texas perf, GM hot cam,or an XFI High lift from compcams. I'm still gathering parts for the conversion, I.E. fuel system,pulleys etc. So I have a little time to sort things out.
      Mike Martin
