    Results 1 to 10 of 10
    Thread: Pusher puller?
      Dec 2008
      Lehigh Valley Pa
      Pusher puller?
      Ok here is some backround on what I want to do. I had a radiator out of an LT1 Caprice. It was one of those radiators that needed a seperate tank to full as there is no cap on the radiator itself. Well I would like to get rid of the seperate tank and plastic side tanks so I boght an all aluminum radiator. But this tank is narrower and the fans that were on the LT1 rad won't mount side by side on the new rad. So I was thinking could I mount a pusher in front on one side(passenger) and a puller on the engine side on the oppsite side(drivers) so it would end up being like a side by side fan set-up. Would there be any problems with this idea? It's that or ot a 16.5 single fan and that of a small fan I have on my Permacool aux trans cooler. Please don't tell me to go out and get this fan or that fan. If it were that simple I would. I am very tight on cash as the front seal on the trans went, so I have to use what I have.
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      Mountain View, CA
      I saw the thread title and thought perhaps you were buying a Cessna Skymaster.
      True T.
      My blog
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by Damn True View Post
      Nope but I always did love that bird.
      May 2009
      Centennial, CO
      I thought you were talking airplanes too. But I was thinking the A500 I used to work on.
      Jun 2006
      Mason TN
      Quote Originally Posted by The Stickman View Post
      LOL... too bad that ones an RC model
      1986 Monte SS, 427 sbc, Victor E manifold, FAST TB, FAST XFI, T56 6spd, Moser M9 rear 3:70, SC&C G5, Spohn lowers, Pole Position Uppers, Alston Coil Overs, Pirelli all around
      Mountain View, CA
      I wonder, do you need a multi rating for one of those? (The real one not the RC model)
      True T.
      My blog
      SF bay area, CA
      A Pusher/puller title in an automotive cooling forum, gee what else could it be? An airplane, of course!
      Stickman did you try your idea out yet? If the fan blades and/or motors are rated to work in reverse then I don't see a problem, assuming you have the means to mount them to the front in the first place. Some blades only work best in one direction, some manufacturers say theirs work both as pusher/puller, and some have removable/flippable blades so you can position them the same way when switching from one configuration to another. If the mounts fit with little trouble then do it, the temp gauge will tell you if it's working or not.
      I've seen a few factory FWD cars set up with a staggered push/pull fan, except the pusher fan is on the A/C condenser. Without A/C they just run the single puller fan on half the radiator.
      Dec 2008
      Lehigh Valley Pa
      Quote Originally Posted by Ron L View Post
      No I am still tossing ideas around. I have the new radiator and I have some fans latyng around. One is a 16.5 which isn't that bad for the size of the radiator which is 31X19. So i figure that with the top and bottom flanges on the rad the core is about 17.5-18. just not sure if that fan will pull enough to cool it. I am planning on putting the aux cooler out in front so I would hope the 2 might be enough to keep it cool but I have my doubts and simply don't want to do this twice.
      Jun 2009
      Pullers are always more efficient than pushers.
      Aug 2005
      Patterson, NY
      As said, pullers are more effective, and not all fans can be mounted as pushers.
      That being said, if the one fan you have is too weak, and you don't have room for two on the same side, then a second fan, mounted as far offset as possible, should work.
      The most important thing is the capacity of the fans: if they are too weak they just won't work.
      Jason Scheer
