      Huntsville, AL
      TKO Cross member Question?
      I am in process of installing a TKO600 in a 67 camaro and have ran into a slight problem. Factory subframe and factory auto car.
      Problem is that my TKO cross member is further back than the previous cross member mounting points. Basically as it currently stands, I need to drill the subframe for the back 2 holes of the cross member. After calling the vendor, they stated the subframe should have a total of 3 holes per side drilled for either an auto or manual cross member. My subframe only has 2 holes per a side drilled.
      Anybody else ran into this problem before? Are most 1st Gen camaro subframe drilled from the factory with 3 holes per side?
      Adam
      Adam
      Your sub frame should have three holes on each side however some 67 Camaros were built with Nova sub frames and they can be different. But even if you had the third hole in there it wouldn't help you. The Camaro sub frame is recessed for the cross member and it won't move back far enough to accommodate the TKO without hacking up the original cross member to make it fit.
      Huntsville, AL
      Jim,
      PM is replied to. I appreciate your help.
