      quick q on installing driveshaft
      quick q - i'm about to install my driveshaft
      do i need to put any lube or anything on the part that goes into the transmission's tail? like the teeth? or can i just install it dry?
      car is a fourth gen camaro
      thx guys
      Oct 2007
      ridgefield ct
      IIRC you use a little bit of ATF on the splines.
      TN
      WAIT! Is it an Auto or a Manual? If its a Manual... Don't use ATF! Use whatever gear lube you use.
      Benjamin
      Twin Dusters
      Southern Indiana
      ATF is finme to lube a seal anything to keep it from running dry, and if it has new seal SOME come with a synthetic grease on them, heck you can even use vaseline.
      We are in Jupiter Florida home of Burt Reynolds
      trere is plenty of oil all over the seal just taking the drive shaft out just shove it in ..
      Have Fun Bruce
