      Oct 2007
      454 with a 2002 T-56
      Hello Everyone! Being that this is my first post on pro-touring I am really looking forward to the wealth of knowledge you all have. Hopefully it will save me from having to do anything twice. I currently have a 1968 Camaro that was a small blockTH400 combo. I have since sold the motor and trans and now have a stroked 454 and 2002 T-56 (out of SS camaro). My question to you guys is what do I have to do to mate that transmission behind the new big block. Also is there anything I should do to the transmission to help it hlod up to the big block. I have heard the stock T-56 can handle alot of torque, but I also have people telling me I'm going to break it. I am really looking forward to starting the project so once again your ideas and opinions are greatly appreciated. I will also post pics along the way to show progress. The car also has a 12 bolt posi 3.23 gears. I was considering a deeper grear swap however with the deep 1st gear of the T-56 and the gobs of torque of the big block I think I should wait and see before going to a 3.73. Also any places you recommend to order parts would be appreciated. Thanks much!
      Jun 2009
      Decatur, AL
      Well, with the 3.23 you'll probably never need the 6th gear ha ha.
      Welcome to the board btw. You should probably go post in the "welcome to the board" section and show some pics of your ride.
      2001 Camaro Z28 (DD)
      LS3 525hp GM crate engine, built 4L60e
      1974 Camaro Z28 Type LT
      Solid roller 355 sbc with T-56
      Sep 2007
      Montgomery, Tx
      I used a Quicktime Bellhousing (no adapters), check thier closeouts.
      Got mine for a great deal.
      west michigan
      first off welcome to the forum. There's a ton of knowledge here and alot of helpful people to learn from.
      I am curious about this too. I have a big block and would like to go to the t56 but not sure if it would hold up.
      Chad Read
      Jun 2009
      Decatur, AL
      Well I have heard that the T56's are rated to 400 - 450 foot lb's as a "conservative" number. I have also heard of them going a lot higher than that as stock. They're a really strong transmission.
      I'm looking into a big block 454 to stroke to a 496 and put in front of my T-56 but that's also down the road a little bit.
      Belle Plaine, MN
      I got the Rockland Standard T56 (son of Tranzilla) and would recommend it highly. Yes, it's pricey, but I don't worry about breaking it either...and I drive pretty hard in a heavy car. Think about it...
      Scott Parkhurst
