Results 21 to 36 of 36
06-05-2009 #21
i second the group buy idea
06-05-2009 #22
- Nov 2007
- Phoenix AZ
- 119
Hey Ed
Remember, that the lizard Skin ceramic coating is not a vibration damper or a noise barrier.
If you are going to treat your doors, first apply a layer of Damplifier Pro vibration mat, then if you want, add a layer of the LS ceramix coting on top of that. This will gdo great for noise and heat.
The Luxury Liner Pro is just too heavy for inside doors.
APplying th Damplifier Pro over the LS will only trap water, and promote rust. It will do nothing for vibration control. Esentially, what you are doing, is just treating the vibration in the lizards skin, not in the doors sheet metal.
So, Damplifier Pro, the Lizard skin when noise and heat is an issue (or you can use our ceramic/galss coating Firewall)
Hope that helps
ANT
06-05-2009 #23
- Nov 2007
- Phoenix AZ
- 119
Just make sure you use the right tool for the job. It doesn't have to be Second Skin. There are lots of good product out there.
I know ours inside and out so that is what I am comfortable talking about. Plus I profit from it, so I am a bit biased anyway. AS long as you are comfortable with the product, the price and the results, that is all that matters.
BedLiner is a great option when not using any carpet because it will provide a very strong level or protection. It will do very little for vibration damperin and heat reduction compared to real dampers and barriers though, so it is always good to use the Bed liner as your last layer.
I know it is a different beast, but most of our off raod guys go with Damplifier Pro on the inside of the cab, then follow up with a bed liner on top of that (we sell a DIY Bed liner that is very strong)
The underside of the vehicle gets treated with Spectrum (noise coating) or Firewall (ceramic/glass heat coating)
You might want to consider doing something similar to this in your Roadster. The noise and heat results are awesome!
ANT
06-05-2009 #24
- Nov 2007
- Phoenix AZ
- 119
06-05-2009 #25
- Nov 2007
- Phoenix AZ
- 119
Well, the best will require the use of a vibration damper, and a barrier.
The lightest ones that we offer are
Damplifier Lite
Heat Wave
one layer of each will add about .50 lbs per sq foot.
You might end up adding about 35 lbs by the time you are done:
60 sq feet Damplifier Lite
5 Sheets (45 sq feet) Heat Wave
1 can adhesive
1 small roll foil tape
That is a very light and effective combinations.
Again, there are lots of quality companies out there that have good products so I suggest looking around. I happen to be the only vendor on this forum that is representing an insulation company, but I am sure you can google up all kinds of good ones.
ANT
06-08-2009 #26
06-09-2009 #27
- Oct 2008
- Durham,NC
- 664
