    Results 1 to 20 of 31
      Nov 2007
      Germany KMC
      Chevelle with GTO seats Rear deck
      I made me a rear deck so I could blend in the GTO rear seats, along with making a nice place to mount the speakers.
      The rear seats I cut down and re-welded the frame so the height better matched the stock seat height.
      Now all I need to do is make the arm rest/filler on the sides, have the headliner installed and sail panels covered.
      Not sure if I should do head liner material or the "leather" material on the sail panels.
      save
      Adam
      69 Chevelle SS 396 < --Sold
      67 Camaro
      93 Beretta GTZ
      09 R50 VW Touareg
      May 2008
      SoCaL-Pico Rivera
      can you add more pics on how you did this. I am wooking on the front seats right now. If you have pics on what you did that would be great.
      Thanx
      Feb 2009
      Halifax NS Canada
      Did you leave the GTO stitching in the front seats or have that panel covered or replaced. What did you do on the outside edges of the rear seat.
      Nice work it looks great
      Would love to know more about the mods made to the seat frame, i am using the same seats for the rear of gsx. I have the bottoms fitted but the backs are way to tall. I was thinking of cutting about 5 1/2 inches out about 3/4 of the way up. Any advise would be greatly appreciated
      Nov 2007
      Germany KMC
      I had removed about 3-4 inches from the bottom of the the frame and cut the foam from the bottom.
      I used expanding foam to blend between the rounded seat backs the the flat rear deck. I then covered with padding, I used a batting material but I should have used a foam type. I say this because the batting bunched up a little and caused a little bit of wrinkle when I rolled and glued.
      Adam
      67 Camaro
      93 Beretta GTZ
      09 R50 VW Touareg
      Jun 2009
      Greenville, SC
      GTO seats for a convertible
      I too am interested in updating my rear seat in my '68 Chevelle. Has anyone tried this with a convertible yet? Thanks.
      Jun 2009
      Greenville, SC
      I also have a 68 Convertible Chevelle. I have already purchased the rear seat on ebay and I am looking for more information on what needs to be done to make it fit. Thanks
      May 2007
      Las Vegas
      Looks good. I like the blend to the top of the back seats. I have a 67 Chevelle, the same GTO seats and will be doing the same thing...
      Rich
      1969 Camaro (in hibernation)
      Feb 2008
      Great, another project to add to my car!
      Nov 2007
      Germany KMC
      I realized that I need to add an update.
      If I was going to do the rear deck again I would to a one piece panel across the face that mates to the back of the seat (the bulged part) I would also only use a thin foam padding between the MDF and the simu-leather.
      Adam
      67 Camaro
      93 Beretta GTZ
      09 R50 VW Touareg
      May 2007
      Iowa
      GTO Seat Width
      NVMYSS
      Thanks for the help and all the photos you have supplied us. They have been a great help. I really want to add the GTO seats to my car. My problem is the width.... I assume they are not as wide as an original. What did you do? Any Chance you could post a few pictures? Any help would be great! or you can just email them to me
      [email protected]
      Nick
      Dec 2009
      ri
      I am currently adding the rear seats in a 65 GTO- I am cutting the center section and moving the seats outboard to match the fronts. i will have to make a wider center section and about 3" wide bolsters on the outsides of the seats
      Apr 2010
      Chandler, AZ
      What are you using to widen the center?
      70 Chevelle LS3 T-56 Whiplash Rushforth Wheels.
      Paint design by Jason Rushforth
      McMinnville, TN
      I just put 2010 Camaro SS leather seats in front and back..little mod on the brackets and they fit awesome!
      May 2010
      Currently adding the front GTO's to my 68 but having a lot of trouble with fitting the brackets..PLEASE HELP
      Nov 2007
      Germany KMC
      I used a 1" spacer under the GTO mount.
      Adam
      67 Camaro
      93 Beretta GTZ
      09 R50 VW Touareg
      Apr 2010
      Chandler, AZ
      Quote Originally Posted by nvmyss View Post
      Is that for all 4 holes on the track? Did you do any cutting or just spacers?
      Nov 2007
      Germany KMC
      I think I only used them on the back 2 bolts. But it will vary as I moved mine back a few inches to gain room for my long legs.
      Adam
      67 Camaro
      93 Beretta GTZ
      09 R50 VW Touareg
      Apr 2010
      Chandler, AZ
      Does anyone have a writeup for this swap with Pictures?
