      Connecticut
      Power Door Lock not working
      hey guys, my wifes 06 malibu driver's door lock will not work with the power lock/unlock button. is this an easy fix?
      thank you
      Paul Krol
      1968 Camaro
      Southern Indiana
      depends this car runs through the BCM (body control module) if you can get switch/panel out and test switch with volt/ohm meter for proper operation, other wise honestly ttake it to a good technician as it may require a scan tool, if you want I can email you the 3 door lock diagrams but its pretty intense even for me and I AM a tech.
      Good Luck
      Lee Abel
      AFTERMARKET PERFORMANCE
      Connecticut
      Good Luck
      Lee Abel
      Thank you very much Lee. Iwill take it to my local gm dealer they are good people.
      Paul Krol
      1968 Camaro
