    Results 1 to 10 of 10
      Apr 2003
      Nyköping, Sweden
      Country Flag: Sweden
      Warning on C4 Calipers
      I did some work on my car and it involved removing the front calipers. I couldn't believe what I saw. They were bent! Apparently they are to weak for highpressure systems like my HydraBoost combined with a S-10 M/C.
      I haven't noticed any problems with the brakes, up until now they have worked. I have to admit that they have got a fair share of abuse.
      Look at the picture to see tha angle they now have. I didn't see any cracks or so. They would have held up a while longer.
      I will now change to C5 Calipers which are much stronger.
      Jan
      Jan Suhr
      Nyköping, Sweden
      1969 Pro touring Camaro Z/28 LS1/T56
      Scandinavian Pro Touring Forum protouring.se
      Indiana
      There's an eye opener! I have a few friends running a hydro with those same calipers. I'm going to forward them your picture and hopefully they'll check their calipers.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Loganville, GA
      I heard of people with Mustangs and the Cobra calipers doing the same thing. Something to watch out for with rebuilt calipers.
      Sounds like a perfect excuse to call Stoptech or similar manf for some killer calipers. It's only money.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Sep 2001
      Accord, NY
      Wow - I ran C4 with hydroboost for years with no issues.
      68 camaro - SOLD
      Morehead City, NC
      Quote Originally Posted by Yelcamino View Post
      I'm guessing I'm one of those friends. I will put the Tempest on the lift today and check.
      Later
      Mike
      Newbury Park, CA
      Quote Originally Posted by Rick Dorion View Post
      Wow is right. I'm still running C4/hydroboost.
      Thanks for the heads-up Jan. I'll need to do a little investigating.
      Morehead City, NC
      Quote Originally Posted by Mike Holleman View Post
      Later
      Mike
      I checked the C4/ hydroboosted brakes on my 64 Tempest and all was well. They have approx. 17,000 miles on them with some hard driving, but mostly cruise miles. Hopefully, your's was a isolated case. I do appreciate the heads up Jan.
      Mike Holleman
      I wrench on cars so when comes to bleeding brakes I'm amazed how much alum and case iron calipers flex. One thing that sticks in my mind is a common late model car with alum calipers that look like they're going to snap in half.
      Oregon
      Jan, I mentioned this on lat-g, but if you're running the 15/16" stepped bore S10 master cylinder, then you're capable of generating ~40% more pressure with the same pedal input then with a 1-1/8" bore. That could be a significant part of the problem. For those who are running C4 calipers, the 1996 Grand Sport calipers are pressure-cast versus the earlier ones which are gravity-cast, so they're the better choice if/when you go to replace calipers. It probably wouldn't have made a difference in this instance, but it should increase caliper life where the pressures are more in line with the design specifications for the caliper itself.
      Tobin
      KORE3
      It's what I does.
      Apr 2003
      Nyköping, Sweden
      I have been in contact with Paul at HydraTech who gave me the HydraBoost unit. I won it at the Protouring.com SEMA-dinner in 2006.
      The S-10 M/C is probably a major part of the problem but I have heard about similar problems with C4 calipers with the stock setup of M/C and Booster. In fact one of the rear calipers I got first (LT1 reworked) was slightly bent.
      The Camaro Cup racing circuit here in Scandinavia have banned the C4 calipers due to the tendency to bend.
      Anyway I have ordered C5 front calipers and will also get a Corvette C3 M/C with 1-1/8" bore.
      Jan
      Jan Suhr
      Nyköping, Sweden
