    Results 1 to 17 of 17
      Power Steering noise
      My power steering box on the LS1 engine is making noise after car warms up. I have a power steering cooler which is stock that came with the engine from a WS6, 4 wheel disk, hydrobooster and late '80 fast ratio steering box. Lines are teflon with stainless braid.
      I read somewhere that those lines make noise. Is that true? and why not as soon as doesnt make noise but after wams up? Or do I have another problem?
      67 Pro-Touring Camaro
      ISMAIL
      Burnaby, BC, Canada
      Have you checked to see if the fluid level is low?
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Yes, fluid level is fine.
      ISMAIL
      Auburn, WA
      Air in the system? What does it sound like? Does it make the noise at idle, or while turning the wheel? How hot is the fluid when it starts to make noise?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Whining noise when driving. it doesnt do it when started.
      ISMAIL
      As far as I know if there is air it should make noise as soon as the engine starts.
      ISMAIL
      Apr 2004
      OKC, OK
      what pump are you running? What size lines?
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      1 . I have an inline WS6 power stering cooler on the upper radiator hose which was stock on the engine. Lines are I beleive -5 aerokuip power steering lines with teflon inside and braided steel outside.
      ISMAIL
      Apr 2004
      OKC, OK
      Quote Originally Posted by 67LS1T56 View Post
      lines need to be -6 on pressure side, we prefer -6 on the return as well
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Lines are -6.
      ISMAIL
      Auburn, WA
      Are you running a remote resevoir? What fluid?
      Does the noise pitch change with RPM?
      Matt Jones
      Mechanical Engineer
      Southern Indiana
      have a flush done and use a full synthetic dot 3 power steering fluid.One shop I worked for ,we started usin g it and had great results with it in noisy ford ps pumps.
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      Do you have a remote reservoir? If so is it baffled? It might be aerating.
      Netherlands
      I have a DSE powerstearing pump with remote oil resevroir and \hydra boost afther start up the stearing wheel is lockt til i rev it a bit, then when it comes loose it sqeels when i try to turn the stearing wheel. when im of driving its perfect , when i come back to park the car it squeenls at times ..
      Oct 2007
      ridgefield ct
      it almost sounds like the pump is cavitating, creating bubbles. what fluid is in there?
      I know its probably not but it almost sounds like the pulley is too big. Like the pump needs more rpms, or its aerating.
      Netherlands
      Jeff i gues your right as i have 15% under drive pullys!!, i could also go for a high rpm at idle i gues..
