      May 2008
      One wire alternator overcharging battery
      One wire alternator overcharging.
      I have tried two different powermaster alts and have a brand new battery, checked all connections/ grounds etc and still sending 17v to the battery. Any ideas here? thanks
      Oct 2008
      check your voltage regualtor, but alternator should only put out 14-15v max
      68 ss clone 350 sbc 430hp, 69 454LSX (in progress@ jakes)650 hp ,70 rs 454 mp500efi 550 hp
      May 2008
      not running external regulator. Looking for open short or perhaps bad headlight relay etc. Thanks for the reply!
      bowling green,ky
      alternator
      are they xs volt? if they are, there is a adjustment on the back, a small potentiometer. if not xs volt then?
      even one wire alternators have voltage regulators internaly
      Bad voltage regulator or a short in the alternator could cause this easily.
      Really should do a 3 wire alt
      but you did what you did for a reason
      Josh
