      May 2008
      Does this sound right???
      I have,,,what is supposed to be Global West big block springs for 64-67 cars!!
      I talked to them and they mentioned to check on the spring itself and it will be scribed into it what spring it is!!!
      I checked this afternoon,,,and there is no scribing or anything else to verify what they are!!!
      I measured the springs,,,theyre both: Wire Diameter .72,,,,,8 coils,,,and they measure 13.75" tall!!!
      I have SPC and tall BJ set up,,,the front end sits on its nose,,,and think I may have gotten a small block spring!!!!
      Anyone have any ideas??? Thanks!!!
      Sep 2007
      Southern California
      Quote Originally Posted by 65BuickGS View Post
      Do you mean you have the SPC lower control arms? They lower the car 2 inches. combined with the tall ball joints mounted in the lower arms would give you about a 3 inch drop. You can get spring shims to adjust the height.
      My stock springs (for a 68 GTO) were at least 16 inches sounds like yours are lowering springs (shorter).
      I made some guesses and assumptions but that would get you a lot of drop. This help?
      Jon
      Jon
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
      May 2008
      I just have the upper SPC arms,,,,but your right about losing too much height!!!
      My new rims and tires will here within the next week or so,,,I measured things from the specs I have for the tires,,,and its looking like im going to need to get the front end up somewhere around 2.5" to get it to sit how I would like!!!
      Not so sure it would be a good idea to shim that much or not,,,or if I did shim,,what the proper way to do it,,from the top or bottom??!!
      Maybe the best would be to get another set of front springs!!!!
      Aug 2006
      Cibolo, TX
      I went through the same thing you did - springs dropping my car much more than expected with the SPC arms and tall ball joints. I ended up using the SPC spring spacers (which go in the lower control arm) to dial in the front end height to where I wanted it.
      You can find more information on them here:http://www.specprod.com/CATALOG_DIR/Coil_08.pdf
      The one inch spacer should get you 2.0 to 2.5 inches of lift.
      Here are a few pics of the .5 inch spacers (they lifted the front of my car an inch):
      I got my spacers through SC&C.
      Hope this helps (have fun taking the springs out and putting them back in).
      Rob
      87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
      Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
      May 2008
      Thanks for the link and pic of the spacers,,,think I will give Mark a call on Tuesday and get a set of the 1" spacers ordered,,,,that should get me in the ball park of where I want to be,,,I will have to figure out how to tweak it from there to get it exactly where I want it!!!
      Aug 2006
      Cibolo, TX
      Keep us informed of your progress and post some pics.
