05-17-2009 #1
69 Rally Sport Headlights frozen open
I have a '69 RS that has sat for 20 years and the headlight doors are seized up in the open position. Any ideas on how to break these loose where I can at least operate them by hand? Know of any articles on dis-assembly/assembly? thanks
05-17-2009 #2Is the mechanical linkage siezed, or are the vacuum actuators just stuck? If the actuators still have a good seal (which is unlikely but possible) they may move easier if you just disconnect a vacuum line going into them.
If this does nothing - it may be easiest to remove a vacuum actuator and see if the linkage will move and allow the doors to open. They are located behind the plastic covers in front of the front wheels. You can see them if you look behind the front fender extensions from underneath the car.
The Camaro assembly manual has a good exploded view of how things go together.
