      Appleton WI
      Proper distributor endplay numbers?
      I'm running a hall-effect Mallory distributor and was wondering what the proper distributor endplay should be? Comparing it to my stock HEI, it seems like I have half as much endplay on the Mallory as the GM.
      Should they be the same?
      Jim
      Southern Indiana
      GMs spec is 0.035 or less but you need to have atleast 0.020. Stock GMs are loose from factory, ie stock.
      Appleton WI
      Thanks!
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
