    Results 1 to 18 of 18
      Dec 2008
      motor not going in
      i been fighting with this thing for two evenings now, it's just not going in and i really think i am missing something. 468 bbc into 67 camaro, it's about half of an inch away from getting to the mounts but refuses to go any further, i pulled it back out three times now getting rid of stuff that i thought was blocking it(like heater box). picture below shows how close it is. So the main question is what could i be missing and why it just would not goo any further.
      Mar 2002
      Redwood City, CA
      What motor was in the car before?
      Allen Ortega
      Dec 2008
      350 was there before, i did some searching around and the same frame mounts supposed to be able to work with bbc. I know from factory there were different in order for the manifolds to clear the steering box. The car is manual steering and manual brakes so no brake booster to interfere.
      Unless you plan on pounding the headers until they flow less than a McDonald's straw, I suggest you get the proper mounts for that BB.
      Jonesboro, Arkansas
      Quote Originally Posted by 68Formula View Post
      He's right, BBC and SB motor mounts are different. I found this out in my '68, it had BB mounts and I was wondering why they moved everything and drilled out the rear cross member to make it work!!! Yes there's a difference.
      Carl Wilson
      Dec 2008
      I did some searching about the headers and people say that with 350 frame mounts hooker comp headers work.
      i did however got closer and was able to get one side , the passenger side hole doesn't line up tho... Is this just because they are not bb frame mounts? How people got it working before?
      Jul 2007
      Los Angeles, CA
      BB mounts raise the motor 3/4" over towards the passenger side. You will have issues with header fitment like others have said. You will also have problems with trans crossmember fitment as well.
      Another thing to consider is you will probably need a BB heater core since the SB heater lines will be nearly covered if you get BB frame / engine mounts.
      Classic industries has a nice article describing what you need to change:
      1967-69 Small Block to Big Block Engine Swap
      http://www.classicindustries.com/con...rationTip&pt=1
      I'd get all the correct parts, lots less swearing, hammering and drilling.
      Dec 2008
      heck, so many people told me it would work, but now realize that it doesn't work that well. I will just leave it where it is, get some new frame mounts and finish it off later. The only think i didn't want to do is modify the trans crossmember to work when swapping to bb mounts
      Dec 2008
      i got correct frame mounts and tried to put the motor in again. One side went in but the other side still doesn't seem to want to go in. any ideas on what could be the problem.
      Jul 2007
      Los Angeles, CA
      Is it on the mount, but just too low?
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by 1969CamaroRS View Post
      sure looks like he could simply lift that side up a bit and it'd fit fine. They do not necessarily go all the way down over the frame pads, just enough to get the bolt through the holes.
      Jody
      Jul 2007
      Los Angeles, CA
      Quote Originally Posted by camcojb View Post
      That is what I was thinking.
      Dec 2008
      the problem is that moving the motor up and down doesn't make the holes line up. It always seem to escape the middle by 5mm or so. I'm going to try messing with it more on the weekend but i didn't have anywhere near as much problems getting ls1 to mount in my bird
      Sep 2007
      Denver
      Not likely....but could the subframe be bent due to collision?
      David Beckstrom DVM
      Nov 2007
      Pittsburgh,pa
      Not sure what solid mounts you are using but there are actually 4 different frame mounts gm used! A short sb, a tall sb, a short bb, and a tall bb. Looks like you have the tall bb. If you get the short I bet it lines up. They show them all in one of the catalogs, I think maybe classic or year one. The BB mounts shift the engine to the passenger side and actually twist it a bit. I went through this. I have all 4 sets of mounts!!
      Dec 2008
      i got the mounts from the ricks camaro. The should be correct for 67 with bb and the passenger one is shorter than the driver side one. I see no damage or repair of the subframe and the old motor was in there just fine. This is just weird and i am not sure what to do.
      Miami, Fl.
      You also changed the transmission. Maybe you need to move the Transmission support.
      Central CA USA
      1967 BB engine mounts (the part bolted to the engine, not frame brackets) are not that tall, get shorter versions. The solid engine mounts you have are tall versions 2 1/8" made for a 69 big block. I believe 67 Big Blocks used a 1 3/4" spacing from block to hole.
      My page on it: http://www.pozziracing.com/camaro_engine.htm
