      Feb 2009
      Long island, New York
      starter seems to jam
      when i try and turn the car over, the starter seams to jam and gives off a loud bang. do i need spacers?
      Dom Buffa
      Apr 2008
      Newark, OH, / Concord, NC
      Starter Shims
      You need to shim the starter away from the block, the correct amount of clearance is about .060" (1/16"). Add shim and then manually engage pinion into flywheel and check clearance with a 1/16" drill bit, the clearance is the distance from outside surface of the gear to the root of the opposite gear. Good Luck !
      -Dale
