Thread: Brake Stuck on 64 stang
05-09-2009 #1
- Jan 2009
- 213
Ok the driver side front brake is stuck....im a motor guy I dont mess with brakes heh how do I release the pressure off of it so I can Move it around before the bbq at 3 today?
05-09-2009 #2
- Oct 2007
- ridgefield ct
- 876
first try opening the bleeder valve and see if it'll retract. you may need a prybar in between the rotor and caliper. other than that you may have to remove the caliper.
05-09-2009 #3
- Jan 2009
- 213
yea sorry forgot to mention drums all the way around
05-09-2009 #4
- Oct 2007
- ridgefield ct
- 876
i should have seen that from the "64 stang" DOH! in that case, loosen up the adjuster and beat the drum with a hammer. that usually breaks the rust free. sometimes, rocking the car back and forth will also break the rust free.
05-09-2009 #5
- Jan 2009
- 213
Thanks man yea I finally rocked it loose but i gotta take the wheel off again and beat on the drum cuz I gotta push the damn thing up a hill and its still stickin
05-09-2009 #6
- Oct 2007
- ridgefield ct
- 876
now that it's loosened up some, you should be able to pull the drum and knock some of the rust out. i usually use a small ball peen and a small chisel for the edge. then some sandpaper for the brake surface.
