      May 2009
      nova dash in camaro
      hi does anyone know if you can use a 69 nova covan dash in a 69 camaro i had heard you cn thanks
      If you can get the 2 cars side by side just check the total width of the dashes. If that part is close you should be able to do it with some work. I put a 99 Camaro dash in my 67 Camaro and a 87 Camaro dash into a 79 ElCamino. Just takes time. Good Luck Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Oct 2007
      Paducah, KY
      Do a search. I saw a guy that did and has some pictures. Uses the dash pad of the nova also. Hope that helps.
      Darren
      Feb 2009
      So-Cal
      yes you can, but you have to use a nova dash pad.
      James Faria
      07 GT500 740rwhp
      Feb 2008
      Mooresville, NC
      Quote Originally Posted by jfaria78 View Post
      exactly
      Michael
      Manteca, CA
      Yes....I did it. Alittle trimming here and there....alittle moving of the screw mounts...nothing major. But yes you need to use a Nova dash pad. That also takes some trimming etc. I bought a used one on ebay, trimmed it to fit and then had it recovered in the same vinyl as my door panels etc
      May 2009
      nova dash
      thank you for the helpfull info
