Results 1 to 16 of 16
Thread: chevy crank length problem?
05-02-2009 #1
- Oct 2007
- ridgefield ct
- 876
i'm starting to think that the crank in my car might be a bit too long. mostly because the starter doesn't fully engage onto the flexplate. i have at MOST 1/8in of engagement. and that's if i'm lucky! how long should it be? if it matters i got it as part of the kit from speedomotive.
if it is too long, can i have the mounting surface for the flexplate machined down? or better yet can i just pull the trans out of the way and grind it down? i really don't want to have to pull the motor or disassemble it unless it's an ABSOLUTE last resort. oh, i checked the starter against a couple of others i have and they all extend the same amount.
thanks for the help
nick
05-03-2009 #2
- Jun 2007
- Farmingville, New York
- 70
The bendix won't engage the ring gear all the way, 1/8" or .125" doesn't sound too bad to me. Don't start grinding or modifying things because this will affect the torque converter engagement into the pump and you'll break the pump drive if you're not engaged into it properly.
05-03-2009 #3
- Mar 2008
- Chicago suburbs
- 667
