      May 2008
      Des Moines IA
      L460 Trans to Autometer Speedo
      Is there an adapter needed to pull this off? I believe it has to converted from Elec to Mech. Does the Dakota Digital set-up do this? Any input on this would be helpful. I tried to find a previous post, but came up with nothing.
      Jeff
      Mountain Springs, Texas
      Do you mean a 4L60E transmission driving a mechanical speedo? If yes, there are a few options. Cable-X is one but it is quirky and not a perfect solution. Here's a few threads:
      https://www.pro-touring.com/forum/se...archid=1119996
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      May 2008
      Des Moines IA
      I tried that link, but it said it was not found. Is there an 4L60 and an 4L60E? If there is both I believe it's a 4L60. The motor and trans are said to be out of a 94 Vette. Thanks again for any help on this.
      Aug 2003
      Wanatah, Indiana
      Do you have a controller for your trans? If it has a computer then it is a 4l60e. The only controller that the 4l60 has is for the torque converter lockout.I would think but not sure that that trans would be a 4l60e.
      Mark Antrim
      May 2008
      Des Moines IA
      After doing some reading, it appears the 4L60 is aka 700R4. The 4L60E seems to be a different animal than what I have. So I guess my questions stays the same, but Can re-phrase it to: What, if anything needs to be done for an aftermarket (autometer) gauge to function with a 700R4?
      Edmonton, AB, Canada
      If your Autometer speedo is mechanical, you can pull the extension housing on your 4L60 and install the correct speedo drive gears just like you would in a 700R4. You might have to hit up a local transmission shop to find the correct bullet and hold down to replace the sensor in the extension housing. Then it's just getting the correct speedo cable either bought, or made for your application.
      Colin
      1950 Pontiac 12.82@105
      1999 GTP
      England
      Go to street and performance web site there should be an articule about it when they did the 67 camaro engine box swap.
