    Results 1 to 9 of 9
      Gas tank pressure?
      I cant seem to find the vent tube on the gas tank, the tank has alot of pressure! changed the cap it did not fix the problem, car is a 69 camaro with a 383 stroker 750 edlebrock carb
      69 camaro, 383 stroker, 700r, 3:73 auburn, JL stereo, marquez lights front/back, adj qa1's, custom dash, sts swaybars 1 1/4-7/8, global west a-arms/subframe connectors, suede interior.
      http://hobbystage.net/camaro/jigga99/
      Feb 2007
      USA, TN
      Which tank, and pickup are you using? ECC / NonECC?
      factory tank
      Feb 2007
      USA, TN
      There are two types of factory tanks. Are you using an ECC or non-ECC tank? If you have a non-ECC tank with an ECC pickup tube you will not have a vent.
      We need to know what you have. It may be as simple as adding a vent to the pickup assembly.
      ECC tanks will have vent lines in them. Non ECC tanks do not. They rely on a vent in the pickup assembly. Either way, the factory never intended these tanks to vent directly to the outside. However, most people do vent them to the outside now.
      Is there an easy way to tell with out going into the tank?
      USA
      My 69 has a vented gas cap.
      I guess it vents through the cap ??
      I put a non-vented cap on it a couple of years ago ( to keep fuel from sloshing out of it ) and it built up a lot of tank pressure. ( To the point of expanding the fuel tank )
      So , I went back to a NEW vented cap to relieve the pressure.
      The new vented cap does not let fuel slosh out.
      I guess the original one that came on the car was worn out..
      Jeff Tate
      U.S.A.
      Sep 2002
      San Jose, CA
      I'm not a fan of vented caps... most of them don't have checkvalves and can slosh fuel. Bad for the paint AND a firehazard.
      I think by '69 most of the cars had charcoal canisters
      Just call me Brett
      Henderson,NV
      I thought they were vented to the atmosphere. Anyway, it doesn't really matter because you need a vent equal to your engine feed line size regardless of how they did it 40 years ago. I wouldn't use a vented cap on a 69. Every time you hit the gas it's going to drop fuel all over the road.
      Todd
      Chicago suburbs
      I agree with Vegas69 about the vent size, but I'm running a vented cap on a stock tank with -8 AN feed line (all new), and I've never had any fuel slosh out. In the future I will install a new tank and I'd like to run a real vent, but to where?? I hate the smell of gas, so I guess the only way to eliminate fumes is with a charcoal canister, but I never see those used.
