    Results 1 to 10 of 10
      T56 Flywheel Explanation
      I am currently installing a 1994 LT1 T56 box onto my 1988 SBC350.
      I am ready to connect the box prior to install (will be using the hydraulic clutch).
      I have read the advice on this forum about using the flywheel from the LT1 engine? (which i do not have at present!). What i would like to know is why this flywheel needs to be used? Just trying to understand, as over here in the UK, one or two people are trying to understand why, and seem to think the 1988 flywheel may be ok?
      Any further info will be gratefully appreciated!!!!
      Last edited by MinesGT; 04-25-2009 at 09:56 AM. Reason: To make the title more correct
      Walla Walla, WA
      Take a look at the opening posts in this thread: http://www.camaros.net/forums/showthread.php?t=98387
      The short answer is that the LT1 T56 uses a "pull" style clutch, rather than the more standard "push" style clutch, and the flywheel to which the pull style clutch bolts is substantially thicker than a standard flywheel.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Thanks for the quick reply Mike.
      I do not know much about these engines as such, but would there be a balance issue?, or because the block is the later block is it a straight forward "bolt and play" with the LT1 flywheel?
      again, many thanks
      Walla Walla, WA
      If your 350 is a one piece rear main seal engine and internally balanced, I believe an LT1 flywheel would work.
      Jul 2008
      Dallas, TX
      1988 should be 1 piece seal, and being so it should bolt right up. It is thicker, also a 350 should be (usually) internally balanced.
      '69 Chevelle - LQ4/T56
      '71 GMC SWB Fleetside - LM7/AR5
      Again, many thanks for the replies.
      At least i will be able to explain why, when i ask the suppliers!!
      cheers
      Dunwoody, GA
      The LT1 engine is not an internally balanced. It is actually balanced by the flywheel. So this means you'll need to remove the weight that should be on the LT1 flywheel. It's on the opposite side from the friction face. I call this the back side but just wanted to be clear. Your 88 SBC, is it internally balanced? If not was it balanced by the balancer or the flywheel? You'll need to replicate the balance with the LT1 flywheel if the 350 was balanced by the old flywheel. If the 350 requires a zero balanced flywheel, have the LT1 flywheel checked and don't just depend on removing the weight off the back side to be accurate. If you're buying a new flywheel from say McLeod, you should be able to get a zero balanced LT1 flywheel or at least one that has the weight bolted on and not cast along with the flywheel as a factory piece is done.
      Trey
      ~ Jon Hammond
      La La Land, CA
      Also it is a tiny bellhousing and will only fit a 153 tooth flywheel inside of it.
      You can bolt an LT1 T56 flywheel to any 1 pc rear main seal SBC as they are typically internally balanced.
      Tyler
      Nov 2004
      Dallas Texas
      sbc flywheel
      I may be wrong here but I believe the 1pc 350's are not zero balanced as the flex plates I have seen and replaced ARE counter weighted
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      The LT1 style T56 uses a 153 tooth externally balanced one piece seal flywheel.
      GM switched to a one piece seal on all their small blocks in 1986 which requires the externally balanced flywheel. The change to the crankshaft flange required that extra weight be added to the flywheel. All one piece seal small blocks are externally balanced.
      If your engine is stock and hasn't been internally balanced, then the LT1 153 tooth flywheel will bolt right up and will work with your SBC 350.
      No problem. You're good to go.
      John
