Thread: Fuel Injected vs. Carburetor?
Wow Paul! I may need to get back in touch with you once I get this set up and going! I have my build sheet getting put together, and I am thinking this may be the worth it way to go. If you are getting 20 MPG, the the money is worth it since you get it back in fuel!
Curious--what EFI are you running? I was looking to do the LS style, but I think I am going to go with the Pro-Flo2. I will admit, I was originally going with the LS style for the looks
04-27-2009 #2
- Dec 2004
- 203
Holley Stealth Ram
Cmarcus,
I'm running Holley Stealth Ram, with a comp cams EFI cam and roller lifters and rockers (1.6). I purchased the entire HSR used on eBay for $1700 with a laptop to tune it included. Heads are AFR 180s, purchased these used on eBay for $1100, had a set of 186 chevy heads that flow nearly as well but wanted to get rid of the forward and high mass since i autocross. Block is a stock 2 bolt main bored to 355, nothing special at all. Compression is only about 9.5 to one, could be a point higher with Al heads, EFI, wideband O2 and knock sensor.
To be honest, it may be capable of 25+ MPG on the highway, i have done no tuning at all except a little work around idle to smooth it out. I just downloaded what looked like the closest tune to my set-up off the of the website at Holley and ran with it!! I have the air/fuel ratio set a bit on the rich side to be safe, so it's not tuned for economy at all. I'll get around to tuning it sometime...but right now i'm too busy racing and having fun!
The Comp Cams software Camquest estimates the HP topping out at 406 at 5500 RPM and the torque coming in at 435 at 4000 RPM. Of course these are just computer similations, i haven't had it dynoed or anything.
I'd be happy to help you with your project if i can. You may also check out my website (link in sig) for some blog action of my build.
Good luck!
Paul
