    Thread: gasket
      Jan 2009
      Cannes, France
      gasket
      Hi guys
      Please help me. Want to buy new head gasket but what happens if I buy a bore 4.010 if my bore is only 4.00 and what thickness should I choose.
      I want to get the SCE Titan gasket and my motor is a ZZ4 350 with the fastburn heads, I also run a procharger F1.
      How do I choose?
      Sep 2002
      So. Cal
      Quote Originally Posted by kenhaw View Post
      Hi guys
      How do I choose?
      I tried the Titans without success. (I didn't even get into the boost--lasted one weekend--leaked water) I since put the Cometic MLS gasket with Permatex high tack head gasket spray. So far so good...full boost..full power...day at the track
      Ensure flat surfaces to within .0015 max (end to end) with a better then 20ra finish.
      If I remember right, my head gaskets are 4.180 on a 4.140 bore. Smallest Summit Racing sells online for Cometic Ford/Chevy V8's are 4.030 which I belive would work for your application.
      .040 thickness is around the standard and what I'm running.
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Sep 2002
      So. Cal
      Also I should say if you don't have a flat and smooth finish, the Cometic MLS and SCE Titans have a harder time sealing. I've had better luck with a plain ol' standard Fel Pro. They just doesn't handle a lot of cylinder pressure well.
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
      Apr 2008
      Newark, OH, / Concord, NC
      Gasket
      Fel Pro also makes a MLS gasket, it works great in our race engines and we have tried just about all of them
      -Dale
      mo
      I have always had best luck with Fel-Pro myself
      Thall shall fear no amount of boost, For thy bottle is with me.......
