Results 1 to 10 of 10
04-21-2009 #1
Bypass Filter kit, Amsoil - Anyone use/comments?
I need to relocate my oil filter due to not being able to take my oil filter off without dropping my oil cooler lines. Between the kickout in my oil pan, headers and oil cooler lines there is no way to get a standard filter off.
I was looking at filter relocation kits, but then got thinking about maybe adding a bypass type oil filter to the system as well (since not much more work/$ might as well). Amsoil seems to have a pretty good kit (BMK23):
http://www.amsoil.com/Storefront/bf.aspx
Anyone ever use or any comments? Any other kits similar by other manufacturers? Not tied to Amsoil just what I could find easy.
As far as oil for my motor goes, planning on running regular mineral until at least 500-1000 miles then switching to a good synthetic.
Thanks in advance!
04-21-2009 #2Bypass filters are very good.
For those that don't know what they do, they filter only a small amount of oil that is pumped, compared to the full-flow filter that is normally used (and must still be used with the bypass filter). The bypass filter has a much finer media and will remove particles that the regular filter cannot.
Bypass filters are quite common on big diesel engines and with the right media can even remove soot particles from the oil.
Now, other than a bit of piece of mind I am not sure you will actually see an advantage from the bypass filter. If you change your oil regularly you probably won't allow enough particles to build up to wear the engine enough to notice.
If you run extended oil changes then I think you should install the bypass filter. With a good oil I still don't think you'll see a difference in wear, but it'll help keep the full flow from getting clogged.
Believe it or not, one of the best bypass filters out there uses toilet paper as filter media.Jason Scheer
04-21-2009 #3
