Results 41 to 60 of 124
Thread: Monza Spyder, first-car project.
05-21-2009 #2I'm assuming the fusebox has power if other things are working?
make sure the fuse contacts are not corroded, and test the fuses with your multimeter just to make sure they're good. i've had fuses that looked good but weren't.
if all else fails, you might need to pull the fuse box to find the break.
did you check grounds?
05-21-2009 #3I don't know which grounds I should check... : p
- Andreas Unes, Norway.
1978 Chevolet Monza Spyder (first-car project)
05-21-2009 #4
- Nov 2008
- 48
05-25-2009 #5Finaly got power to the dash again (:
05-30-2009 #6Update:
Wires done the right way now, no fancy fast-connection units, Tin "welded" now
(Ignore the blue "Clumps", been removed now)
Dash back in (again):
Anyone got a idea what this could be?
Just had to : D
06-13-2009 #7
