- Oct 2007
- 53
Alignment Specs, Pinion angle GBody
Hey guys, I havent posted here in a very long time but I'm hoping to get a little help from you guys on my alignment. I need to go get the car re-aligned and I'm wondering what specs it should be aligned to? The car is primarliy a street car with the occasional run down the dragstrip. Also what do you guys feel is the best pinion angle to set it to? I have ideas of my own but I would like to hear what the general concensus is. Thanks for your help and ideas! ----Jeremy
Specs: 86 GN, 850HP, ATS spindles, 1" drop springs, boxed lower A arms, 36mm front swaybar, Moog replacement front bushings, SPC adjustable upper a arms, Hotchkis rear boxed lowers, 1 5/8" rear swaybar, double adjustable UMI upper rear arms, 1" drop BellTech rear springs, 245/40R18's front -315/30R18's rear.
