      Newbury Park, CA
      Cometic Head Gasket Leaks?
      Has anyone had issues with Cometic Head gaskets seeping oil on a Big Block Chevy? A quick search of the forums turned up a coolant issue but no oil. It seems that I have oil seeping from both head gaskets and it is making a mess. It collects on the riveted tab that holds the gasket layers and drips down the side of the block. I checked, and it is not the valve covers that are leaking. I have to dig out my paperwork, but I believe the block deck and heads were well within spec as far as surface finish. The heads have been retorqued and the gaskets installed dry as directed by Cometic.
      Has anyone used a standard perma torque FelPro in a boosted application (8-10 lbs)? I have used them on nitrous applications (200 shot) and never had a problem, or an oil leak.
      Mike
      Mike K.
      67 Camaro RS
      Aluminum 509, Procharger D1-R
      CarCraft Feature
      Hesperia, CA
      We have used the perma torque many times in low boost applications using roots style blowers. I believe that the block and head need to be finished differently with the cometic gaskets as opposed to the perma torques. I would make sure those surfaces were prepped for cometics first.
      I have used the perma torques in many applications around 10lbs of boost without o-ring'ing in the block.
      Good luck...
      Dale Lee
      Dale's Speed
      www.dalesspeed.com
